08-11-2009, 12:46 PM
Shifting from First to Second
I have a 2002 Road King Classic and have recently experienced a problem when shifting from 1st to 2nd. From time to time it doesn't always engage in gear when shifting. I only experience this from 1st to 2nd gear. The shift lever is somewhat close to the footboard so I'm wondering if it is not allowing the lever to be fully depressed. I can reposition it upward to see if that fixes the problem. The only reason I think this might not be the problem is that this problem has just started and the lever hasn't been repositioned in over a year.
What say ye who are smarter on all things mechanical? Other than repositioning the lever, what else should be checked?
With sufficient thrust pigs fly just fine.
08-11-2009, 12:49 PM
sounds like it is your shifter pawl adj.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
08-11-2009, 01:47 PM
If that's the case, how much time should it take a mechanic to fix it? Thanks so much for your help stroker.
08-11-2009, 01:58 PM
1st gear to 2nd gear is up,... not down,... or perhaps are you using a heel shifter that you think is positioned too close to the floorboard?
Did the Corinthians ever write back?
08-11-2009, 02:23 PM
I'm heel shifting so in that context it's down.
08-11-2009, 02:46 PM
So, have you tried toe-shifting to see if you have the same problem?
2005 Fat Boy
95", se251 cams
HTCC CNC Heads
Heavy Breather AC
SE Pro II Slip-ons
08-11-2009, 02:58 PM
I haven't toe shifted since my Honda days back in the 70's! But what the heck, I'll give it whirl. If the problem goes away by toe shifting then do you think it's due to the heel shifter needing to be repositioned higher so it doesn't touch the floorboard?
08-11-2009, 03:01 PM
Even if you toe shift, if the heel shifter is too close its still going to hit. If it didn't do misshift before (and you didn't reposition the shift levers) I doubt it,... unless of course the heel shift lever slipped a spline. That could be...
Also check the shift linkage rod for loose bolts and adjustment.
08-11-2009, 06:17 PM
after thinking about it if it only happens from 1 st to 2 nd then it probably isnt your pawl adj. or the pawl spring broke.
if it happens in all the other gears then it could be the pawl.
easy way to tell is . after shifting into 1st lightly lift up on the shifter to reset the pawl manually. if it happens in the up gears also..lightly push down on the shifter to reset pawl before going to the next gear.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
08-11-2009, 06:36 PM
It only does it from 1st to second so that's what has me puzzled. It seems like if the shifter was hitting the floorboard then the problem would manifest itself with all gear shifts.
Thanks for your tips Thrasher and Stroker. I'll get it checked out and report back as to what the problem was.
08-11-2009, 09:39 PM
I haven't actually measured the travel, but I think my shifter travel is slightly more going between 1st and 2nd than between any other gears. I notice it more when downshifting from 2nd to 1st. It may be slightly more space between gears to hit neutral....or it may all be in my head. The simple solution is to adjust your heel shifter up a tooth on the shifter shaft and see if it solves the problem. It's only one allen screw to loosten it and move it.
"To sit back hoping that someday, some way, someone will make things right is to go on feeding the crocodile, hoping he will eat you last - but eat you he will." – Ronald Reagan
08-11-2009, 10:13 PM
Works for me NH.
08-12-2009, 09:25 AM
07 RK here. This has happened to me with the Harleys I've owned, and usually it's just me not performing a solid shift. I noticed this happening after a long ride, hot ambient temps, and I'm a little tired. I don't realize it until I've miss 2nd gear, and the engine revs a little to wake me up. The next time I shift is solid as my brain tells my boot and leg not to be so lazy. This might not be your case, YMMV.
Thorns
I'm just a rider who's living a dream on a Road King!
08-12-2009, 05:27 PM
Thorns
Initially I thought perhaps this was the case with me as well but it has happened even when I've been deliberate about shifting harder.
Stay tuned and I'll let everyone know if it turns out to be something minor or not so minor.
08-12-2009, 06:59 PM
Sounds like a good time to go to a Baker 6 speed and no more problems.
06FLHRCI
