What modifications would have to made to an '88 FXSTC to install this unit ? Spec states fit is for model years '90-up EVO. My friend has an '95, and the only obvious difference I can spot between his drivetrain and mine without disassembly is the starter assy. I'm quite happy to replace my old and tired starter but if I'd have to replace the tranny as well it might not be worthwile.
Any help, suggestions and advice would be appreciated.
Isn't that a "tappered" shaft tranny & I believe the 90 & up are the splined shaft? Almost certain that your clutch hub is set on a tappered output shaft & a key. The belt drive is set up for a splined shaft. If you want to up grade to thier 6-speed,new starter, then the belt drive will work. Just went through this with my friends 85 FXR.
You are rite..Ooops I forgot that part.
R&R/Hyperformance 124" 143hp/144tq SAE
R&R billet heads
R&R 5 piece crank
R&R two piece Cam plate
Dave Makie 630G CAM
Hyperformance ductile Iron cylinders
11.53:1 comp.
55mm Max FlowHPI
D&D Borzilla
Baker OD6 tranny
Baker Plus 1 oil pan
Fueling pump
Thanks, you're right I've got the tapered shaft. Found a packackage at Jireh - 6sp tranny+belt kit for 1100 and change, at a different e-store they asked 1250 for the belt kit alone. Maybe I'll replace the tranny afterall and save 150.
hey did you get this kit?whats included as far as cluch stuff? know any body thats runnin this ,thanks
