9) Now run the wires over to were you plan to install the calibrator, careful to avoid sharp corners and edges, then use wire ties to re cover the wire harness, and put all wires and covers back into the stock locations. Be sure to replace all the wire ties you cut off at the beginning, they were put there for a reason, and they need to be there still. make sure they is room for the battery to go back in place without pulling on any of the wiring. It's a tight fit in here, but if you plan it out right, it will fit just fine.
10) Now lets go on to the mounting of the calibrator unit. If you are going to use the spot I am, clean off any dirt or oil and with some double sided tape( I used emblem mounting tape from 3M.) connect the wires and attach the unit to the bike.
Use the calibrating information provided by S&S to pre-set the unit.
Leave the side cover off so you can adjust it on your test ride.
Now replace the battery and put the bike back together (Leaving the left side cover off for adjusting) andf get ready to ride.
Once you get it running, you will want to take it onto a freeway or area you can go 60MPH.
Use a stopwatch and the mile markers, hold you speed at 60MPH and as you pass the mile marker, start the stop watch. I suggest you go at least 10 miles, Ideally, You should read 10 minutes at the 10 mile marker. (60MPH is one mile a minute). Adjust as needed and start again.
Then you can use the Odometer check, again with the mile markers, as you pass one, reset one of your trip meters. Again, go at least 10 miles, Ideally, it should read 10 miles after 10 mile post.
When I checked mile, I calculated a speed error of -7. I covered the 10 miles @60MPH in 10:19.0 seconds. and the return trip, I showed 10.1 miles @ the tenth mile post.
That is a 1% error to the meter reading fast. Since ther S&S unit does 2% changes per unit, I will leave it be, better to read faster then you are really going, even if it's 1MPH, and it is a heck of a lot closer then it was before.
the gearing change I did (An Andrews 30 tooth drive pulley) is just about prefect for this bike, in the area I ride in and now my speedometer read correct.
One last thing you need to know. It's about the 6 speed light, It will no longer work after you install the calibrator.
Why?
The 6 speed light is controlled by the speedometer (TSSM) and there is no sensor telling it the bike is in 6th gear. It is a program inside the TSSM that compares the RPM to the speed signal, when it matches the programed parameters, it turns the light on.
Since the speed sensor signal has been changed, it no longer will match, so the TSSM thinks the bike is in 5th, not 6th.
As far as I know, to fix that you would need to change the TSSM program, and if you do that, it will void any and all warranties on the bike as it will be called tampering.
Have the bike run right and give you the correct speed reading, or have a useless silly light.
I chose the one to help me avoid speeding tickets.
I hope you have found this useful.
