JekillandHyde.euJardineProducts.comDiamond Bar ChoppersBikeBanditDan Vance RacingRRcycles.comFuel MotoPro PadMotorcycle.com
Pro Pad
Old 07-19-2009, 12:54 PM   #1 (permalink)
Chop15 is on a distinguished road
Strange sound please help "Clutch Hub ? "
This on has got me ??????????
1997 FXSTS 21,000
This sound is a werrrring coming from the primary drive ? tranny ?
when i pull the clutch in noise is still there , when i lean the bike over on the primary side the noise gets a louder , when i lean the bike the other way noise gets softer ???
Clutch hub bearing going out ?
man i just don't know please help
Thank's Chop
Chop15 is offline   Reply With Quote
Old 07-19-2009, 02:07 PM   #2 (permalink)
hbmc's Avatar
you're not going to know till you pop that primary off and look around unfortunately...
Your main bearing is a sleeve on your mainshaft should have about 1/8th max space between the pully and the back of that sleeve. In your clutch hub there is a bearing that may be going or your inner keeper with thrust washer found under your reverse threaded clutch nut the keeper may have come unzipped? Hard to say till you get in there. Clutch comes off as a whole basket so do not worry about any special tools to check it maybe a puller as the splines get sticky and sometimes need a good constant pressure of pulling to get it to slide off the shaft. Check the bearing play should be slim to nill. If your bearing is pushed up against your pully only a dremmel to get that off. Not sure of your year and any difference as my EVO 91 though? I doubt tranny though and you did check the tranny fluid level I am sure.
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
hbmc is online now   Reply With Quote
Old 07-20-2009, 06:15 PM   #3 (permalink)
Cracked into the primary today..... everything looks good
No play side to side on the basket ? or in and out
could'nt realy see the hub bearing
Maybe i should just change out the whole clutch hub and basket ?
Thank's for your reply
Old 08-05-2009, 09:25 PM   #4 (permalink)
hbmc's Avatar
if the bike is running and no metal and it shifts I would ride it.
1991 flstf 'fat-boy
2-1 White "E-pipe"
