BikeBandit
ProCharger.com
Motorcycle-CommunicationSportbikeTrackGearMBO EnterprisesFuel MotoMotorcycle.com Classifieds!
CycleGear.com
Old 07-15-2009, 06:11 PM   #1 (permalink)
slowasstrain is on a distinguished road
transmission pulley removal
im putting an andrews 30 tooth pulley on my 08 softail along with a 70 tooth rear pulley and want to know if theres any special tools or tricks to get the front pulley off.
slowasstrain is offline   Reply With Quote
Old 07-15-2009, 07:06 PM   #2 (permalink)
Coolmaker's Avatar
Read the service manual, spelled out in depth there.
06FLHRCI
Coolmaker is online now   Reply With Quote
Old 07-15-2009, 07:14 PM   #3 (permalink)
yea i did. i need to know if i need the specific tool to hold it of if theres another trick
Old 07-15-2009, 07:55 PM   #4 (permalink)
hbmc's Avatar
main bearing puller and deep socket and a 1 1/4 see harley51 on ebay has great tools as well as georges garage one of the sponsers here.... inch and a quarter socket with a breaker bar thread are left handed on the maishaft and regular on the front sprocket
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
Old 07-15-2009, 08:04 PM   #5 (permalink)
now im confused the manual says nothing about a main bearing puller.
Old 07-15-2009, 08:15 PM   #6 (permalink)
hbmc's Avatar
I'm sorry right you are just the deep socket to pull the nut off the shaft and the 1 1/4 as you need to pull the clutch basket off and it comes off together with the chain and front sprocket Use a piece of plywood about 2 inch wide and about 4-5 inch long and loosen the adjusting shoe so you don't crack the nylon shoe with the prssure to loosen. slide the wood in between the teeth and chain to get the torque to loosen the red loctite and 165lbs of torque on that front nut. (regular thread) then loosen the clutch hub (reverse thread) and slide the two off as an assembly. They say a puller is not necessary to get the clutch hub off but I use one as I find they get sticky even though they are splined. (you will see) Change all the seals while you are there. jack shaft, quad seal, you got the inner off so change the shifter seal too as you can access that when the inner is off---You know you are almost there your choice.
1991 flstf 'fat-boy
2-1 White "E-pipe"
Old 07-15-2009, 08:31 PM   #7 (permalink)
so i dont need to pull the mainshaft bearing? it will come off with the clutch assembly
