Do I have problem?
Hi,
I'm a first time HD owner and about a month ago I purchased a 2000 DWG. When I was cleaning it up I noticed a thin film of oil on the bottom of the primary case, so I cleaned off and re-torqued all of the screws, plus I checked that the drain set screw was in correctly and at the correct dimension. After taking a few short rides I let the bike cool down and the film of oil is back. Is this normal, or do I have an issue?
Thanks for your help,
Hedghog
