Motorcycle.comPro PadDiamond Bar ChoppersFuel MotoProCharger.comJekillandHyde.eu
Motorcycle-Communication
JardineProducts.com
Old 07-12-2009, 10:54 PM   #1 (permalink)
squale147's Avatar
squale147 is on a distinguished road
6-speed vs 5-speed
hey guys.. im thinking of making my 5 speed a 6 speed.. who has done it, and is it worth it?? thanks for any info
motocross#147 drag racing#4933
squale147 is offline   Reply With Quote
Old 07-13-2009, 12:11 AM   #2 (permalink)
Sarge7's Avatar
Sarge7 is on a distinguished road
Baker makes a 6 speed drop in that fits the 5 speed case and their are a couple others out there that also make them.
Closer ratios in the 6 speed - with 6th being a overdrive - you will notice a liitle more shifting with the 6 speed - but you will also get a little better gas mileage on the hiway in 6th gear due to the lower rpm's. - Top end will go up a little but for my money - I'd put it into the engine ie: cams, head work.
jus my 2c's worth
Sarge7 is offline   Reply With Quote
Old 07-13-2009, 01:00 AM   #3 (permalink)
fdonathan is on a distinguished road
Six speed has its advantages, but there is that whining sound in 5th gear on those 6 speeds, somewhat sublet and I suppose you get used to it but it's there. Love my ride but I do try to get out of 5th asap.
fdonathan is offline   Reply With Quote
Old 07-13-2009, 01:40 AM   #4 (permalink)
TheNowhereman's Avatar
haven't noticed any whine.
In my 6, 1st thru 5th are stock.
6th is an overdrive.
After a while, I find myself reaching for a 7th sometimes. Hehehe
Nowhereman who else?
Old 07-13-2009, 04:47 AM   #5 (permalink)
Coolmaker's Avatar
Ditto, me too. But I love my Baker DD6....
06FLHRCI
Old 07-13-2009, 06:09 AM   #6 (permalink)
squale147's Avatar
jus my 2c's worth
thanks for the info.. i did my motor already .. 95inch,se-203 cams, heads done by t.l.c performance,all jims valve train componits. that why i was thinking 6 speed.. thanks again to eveyone
Old 07-13-2009, 09:59 AM   #7 (permalink)
geoff1200 is on a distinguished road
Have the S/E 6 speed in a 03 FLHTI, it's a perfect match to a warmed up 95". Over 96,000 miles and NO concerns.
geoff1200 is offline   Reply With Quote
Old 07-13-2009, 09:07 PM   #8 (permalink)
kennyflhr is on a distinguished road
Got a S&S 6 speed in my 98 RK,love it but there was alot of grinding on the stock case.If I had it to do again,I'd go with Baker.
kennyflhr is offline   Reply With Quote
Old 07-14-2009, 01:31 PM   #9 (permalink)
Ride like the wind
doc ock's Avatar
Unless you cruise at 80 mph, rpms above 3000, there is no need for a 6 speed. If your at 65-70 and shift to 6 gear your lugging the motor. I personally cruise at or around 70 and rpms stay around 2800-3000 which is where the power is on my motor. So if you go beyond that often then go for a 6 speed if not don't waste your money.
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
