The Andrews shafts are about 200 bucks, which could get pretty expensive because you probably should replace all the seals and bearings while you have it apart.
I thought about going that route when I upgraded my `89 to the splined mainshaft, but realized it was much less expensive to go with a used late model gearset.
I installed a gearset from a `99 into my `89 case. My total cost was about 325 bucks.
That was the cost of the gearset ($150) and also all new bearings and seals ($175).
This is assuming the stock mainshaft is the correct length for your application, I have no epperience with belt drives, other than watching my buddy get his jeans caught in the belt at a red light, and down he went...
