BikeBanditCycleGear.comMotorcycle-CommunicationFuel MotoJekillandHyde.euMotorcycle.comAdvanstarMotorcycleShowsDiamond Bar Choppers
Bike Bandit
Old 07-07-2009, 09:18 PM   #1 (permalink)
lobsterguy is on a distinguished road
Andrews 30 tooth pulley
Just installed an Andrews 30 tooth trans pulley on my 07 FXDC and was able to use the stock belt - still have about 1/2" adjustment left. I was worried it might lower gearing too much, but I find the ratios are just about perfect now. Don't understand why dynas arn't geared this way from the factory - I could see touring bikes but not the dynas
I still have my 6th gear light- thought I heard some people were losing it with a gearing change.
Anybody know how to recalibrate the spedo?
lobsterguy is offline   Reply With Quote
Old 07-07-2009, 11:03 PM   #2 (permalink)
robby dmax's Avatar
robby dmax is on a distinguished road
thunder max or the tts !
robby dmax is offline   Reply With Quote
Old 07-08-2009, 12:32 AM   #3 (permalink)
Are we having FUN yet?
Jeffytune's Avatar
S&S speedometer calibration unit.
It goes in line and can adjust the output to the correct the speed error.
I have one on the way for my bike, the amount your off is 6%.
(Edit)
Well, hold the phone on this suggestion. It seems after I ordered mine, i find out that Harley changed the plugs on all 6 spped models, and this unit does not just plug into it.
I am not sure it will even work with it, and S&S does not make one to the 6 speed at this time.
I'm Just Sayin'...
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
92.85 Torque 80.08 HP
Professional Rockat Surgen
Disclaimer.
Old 07-08-2009, 06:23 AM   #4 (permalink)
nhrafan43's Avatar
nhrafan43 is on a distinguished road
Hey Jeff, this is the first time that I have noticed you having the 30 tooth pulley, what are your comments on this for a bagger, were you able to use the stock belt? I have been thinking about it my self.
Night train....................Tuner
43 member here
...............2007FLHTCU
...............D&D Fatcat
...............Big Sucker AC
...............TTS Tuner
nhrafan43 is offline   Reply With Quote
Old 07-10-2009, 03:31 AM   #5 (permalink)
Jeffytune's Avatar
Hi.
I like the way it rung around town. I live in the city that is between two mountain ranges, so easy take offs sure make life easier.
this bike takes off as easy as my old 2006 5 speed model did, and it still quite ride able at freeway speeds.
I really like it.
As to the belt, no I needed a 2 tooth shorter belt.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
