Leslie Kay'sMotorcycle-CommunicationMBO EnterprisesMotorcycle.com Classifieds!
American Side Road CycleSportbikeTrackGearCustom Dynamics
Old 06-30-2009, 12:43 AM   #1 (permalink)
andy81 is on a distinguished road
Redline Shock Proof Drain Interval
I have a 2007 fxd with redline shock proof in the transmisson. When should I drain it 5k or 10k? 30k on bike been doing it every 5k. Seems a little overkill. Any thoughts?
andy81 is offline   Reply With Quote
Old 06-30-2009, 12:54 AM   #2 (permalink)
Nshman is on a distinguished road
hey, i've just started using Redline Shockproof Heavy in my tranny, 07 FXSTB, and I wold think that changing it every 5k is somewhat overkill, imo. 10k might be a little long, but I plan on just pulling my tranny dipstick after 6-7k and checking the color and consistency of it. if i feel that it is looking bad, i'll change it. if not, just leave it alone.
don't know if this helps, it's just my $.02
Nshman is offline   Reply With Quote
Old 06-30-2009, 04:05 AM   #3 (permalink)
semi-retired
FatBobRob is on a distinguished road
Once a year or 10k
I can't means I won't!
FatBobRob is offline   Reply With Quote
Old 07-03-2009, 08:15 AM   #4 (permalink)
RG50 is on a distinguished road
10,000 miles no problem.
'06 Chopper Blue Road Glide,95", 26g,head work,Pro Pipe,Arc audio,lowers w/speakers.
RG50 is offline   Reply With Quote
Old 07-12-2009, 07:48 PM   #5 (permalink)
Fiesta
JPBlueDragon's Avatar
JPBlueDragon is on a distinguished road
Shockproof
I too use Shockproof in my 07 Heritage. Let it go 15,000 and couldn't tell the difference after the change. It was the same pink pepto color coming out as going in. Next to nothing on the drain plug either.
JPBlueDragon is offline   Reply With Quote
Old 07-13-2009, 04:45 PM   #6 (permalink)
Just another Hog Jocky
mtnmotorrider's Avatar
mtnmotorrider is an unknown quantity at this point
No sense in using that expensive stuff if you're going to throw it out every 5 or 10 thou. 20 thou should be considered minimum. I think Red Line says it's good for 50 thou, though. Doesn't make any difference if it's in a Harley tranny or a car tranny, they're just gears after all.
My friends like me; everyone else thinks I'm an asshole. What's that say about my friends?
'07 Road Glide, 103 ci, Big Boyz "Bigger Valve" Street Port 85 cc heads, .030 quench for 10.2:1 cr, SE flat tops, Wood TW 6-6's, K&N air filter, Cobra/Fat Cat bastardized two-into-one exhaust, TMAT ECM with Auto-Tune.
mtnmotorrider is offline   Reply With Quote
Old 07-14-2009, 01:49 PM   #7 (permalink)
rel3rd's Avatar
rel3rd is on a distinguished road
Question
I prefer to change all fluids once a year just as a preventative maintenance/cheap insurance sort of thing.
While on the subject of Redline Shockproof transmission oil, when switching from dino oil, did anyone else NOT notice any difference whatsoever in how easy or hard their bikes were to shift, find neutral, etc...???
I recently switched and the only thing I have felt so far, is $15 lighter, LOL
1997 Softail Custom (FXSTC)
SE hi-flow a/c, ThunderHeader, SE adjustable curve ignition module
RevTech Scorpion wheels & pulley, custom paint, floorboards
rel3rd is offline   Reply With Quote
Old 07-14-2009, 06:09 PM   #8 (permalink)
Faast Ed is an unknown quantity at this point
How often do your guys change the fluid in the read end of your cars?
Lemme guess, every five thou??????
I wouldn't be scared to let the bike tranny go twenty thou, but my analness makes me do it once per year.
Faast Ed is offline   Reply With Quote
Old 07-14-2009, 06:27 PM   #9 (permalink)
rel3rd's Avatar
Actually, I do change all the fluids in my truck once a year too...but only because they have drain plugs on everything that holds oil now (both axle housings, transfer case, transmission and oilpan)....plus, I am a bit anal myself...maybe why wife says I'm an a-hole sometimes, LOL
But back on track, I may remove the Pepto Bismol fluid and put something else in if I hear/read anymore bad about it, like above...
Old 07-14-2009, 06:44 PM   #10 (permalink)
I like trying new stuff now and then myself (the anal thing?) LOL
The shockproof has been good to me for years. Ran Golden Spectrum with the first change on my most recent bike. No complaints other than the cost was around 25 - 30% higher than the shockproof (which is back in there now).
I think some mechanics likely don't like seein' the Shockproof in there when having to do a major repair. Takes like three flushings to get it all out of there (it clings so good). LOL Great for identifying leaks too! A pink drop dang sure ain't coming from your crankcase.
Lots of great oils out there to choose from. There is no one certain brand that blows them all away.
However, I'll likely be with the MTL in my primary for life, as smooth as it shifts for me, compared to the many other primary oils I have tried. Lots of close runners up though.
Sperimenting with some of George's Amsoil in my motor as of late. (Tol' ya I likes to speriment). LOL So far so good. Waiting to see how it holds up with a few thou more miles in the August heat. Expecting it to hold up well.
Old 07-14-2009, 07:46 PM   #11 (permalink)
badfl is on a distinguished road
lucas also has a real good 80/90 syn. also
badfl is offline   Reply With Quote
Old 07-15-2009, 04:17 PM   #12 (permalink)
Ride like the wind
doc ock's Avatar
If you have any doubts get an analysis done. I run 5k on motor, 10k on tranny and primary. Amsoil http://www.blackstone-labs.com/trans..._analysis.html
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
