help replacment of throw out bearing : V-Twin Forum: Harley Davidson Forums
Old 06-07-2009, 05:07 PM   #1 (permalink)
romannumal wants to know Dino or Syn?
I have a 89 fxlr and the throw out bearing went boom....
I need help to replace it. i have the service man. but it dose not say how or what to do to remove and replace. is it that easy that it is not in the man. Any help would be great.
romannumal is offline   Reply With Quote Quick reply to this message
Old 06-07-2009, 06:02 PM   #2 (permalink)
Dan89FLSTC wants to know Dino or Syn?
The bearing we refer to as the throwout bearing is called the pushrod bearing by the Harley parts manual.
To replace the throwout bearing, remove the cover on the right side of the transmission (the chrome cover that the dipstick and the clutch cable go into).
The throwout bearing is on the pushrod assembly that is inside the mainshaft (the mainshaft is the shaft toward the rear).
It will pull out by hand.
Remove the snap ring, the bearing is between the two washers.
I have a manual for `89 softail, it does not show the throwout bearing in the illustration for the `89 clutch, but it does show it in the illustration for the `90 clutch…
Anyway, the worst part of this job is that on some bikes you must remove the exhaust.
Dan89FLSTC is offline   Reply With Quote Quick reply to this message
Old 06-08-2009, 12:13 PM   #3 (permalink)
thanks for your help
Old 06-08-2009, 06:06 PM   #4 (permalink)
pig pin wants to know Dino or Syn?
Just curious way do you think yours is bad. I don't think they go bad that often. How many miles on it.
pig pin is offline   Reply With Quote Quick reply to this message
Old 02-16-2011, 06:02 AM   #5 (permalink)
inlaw's Avatar
inlaw wants to know Dino or Syn?
clutch
my clutch wont release could that be a release bearing?
inlaw is offline   Reply With Quote Quick reply to this message
Old 02-16-2011, 07:34 PM   #6 (permalink)
ridingdutchman's Avatar
ridingdutchman wants to know Dino or Syn?
Sounds like what I went through a couple of weeks ago. Check: http://www.v-twinforum.com/forums/tr...problem-2.html
ridingdutchman is offline   Reply With Quote Quick reply to this message
