Originally Posted by akebhart
Just installed Ultima six speed and have run into a few issues.
1) Speedometer not working. The transmission is in and works properly the spped sensor is in the original speedo hole(the one on the tranny case). Should I be using the speedo sensor hole on the Ultima trap door?
2) Neutral switch working incorrectly. When the bike is in gear...the neutral light comes on...when the bike is in neutral the light goes out. Any Idea how to fix this??
Did you use the speed sensor that Ultima gave you with the tranny?
Gotta use that one and do a little re-wire.
Yes, use the Ultima trap door.
Same thing happened to me.
Instead of having a NO switch, you need a NC switch.
That's why the neutral is back asswards.
