BikeBanditCycleGear.comMotorcycle.comSportbikeTrackGear
Leslie Kay's
Original Bike Spirits
Old 02-20-2009, 08:42 PM   #1 (permalink)
Dyce's Avatar
Dyce is on a distinguished road
Rivera Pro Clutch w/TPP
Just bought the Rivera Pro Clutch with the TPP. Want to know if anyone uses this set up, and if this is a better set up than the regular Rivera Pro Clutch. I talked with a builder/racer about using this clutch (Pro Clutch w/TPP) and he said that he would not use it. He recommends just the Rivera Pro Clutch. He says the TPP has more parts that you don't need to have break and also at low torque it may cause the plates to slip, since the TPP would not apply enough pressure to the plates at low end torque. He has always just used the Regular Rivera Pro Clutch on his builds. Any other thoughts on these clutches.
2000 FLSTF
95ci
10.25.1
190 ccp
Bishop's Performance,
Stage 2, Hammerheads.
SE HC Pistons
SE HG
Woods TW7HR
SE tapered adj. push rods
SE 44MM CV
DTT ignition
Dohtery Power Pacc AC
RB Racing LSR Challenge ProStock "B" Style exhaust
Barnett cables
RB Racing A/F gauge and O2 sensor
Dyce is offline   Reply With Quote
Old 02-20-2009, 09:18 PM   #2 (permalink)
PR3VS56's Avatar
PR3VS56 is on a distinguished road
How much power are you trying to control?
'09 FLTRI, Vivid Black, ABS.
Pri: Amsoil Syn ATF. Trans: Redline Heavy ShockProof. Crank: Redline 20W50HD
'05 FLTRI, totaled 10/17/08.
105tq/107hp
'00 FLHRCI, sold.
Proverbs 3:5-6
Fruit of the Spirit
PR3VS56 is offline   Reply With Quote
Old 02-20-2009, 10:03 PM   #3 (permalink)
Premium octane member
TXCHOP's Avatar
Been running one for over a year now. I initially had problems with the proclutch slipping on the dyno down low in the RPM range.. It was very minor, but did slip just a bit. I have added the TPP on top and all has been good so far. Seat of pants felt crisper, but will be on the drum again next month and i will know for sure.
When i spoke to Rivera, they highly recommended it. They said it would take more power than almost any street bike puts out to make it slip.
TTS tuned by Jd's Cycleworks
Black Boarzilla
Wood's TW9FG cams
Old 02-21-2009, 07:48 PM   #4 (permalink)
Dyce's Avatar
PR3 I really don't know yet. I'm still doing my build, but I know its going to be a lot more than stock.
2000 FLSTF
95ci
10.25.1
190 ccp
SE HC Pistons
SE HG
Woods TW7HR
SE 44MM CV
DTT ignition
Barnett cables
Old 02-21-2009, 10:33 PM   #5 (permalink)
1711tab is on a distinguished road
I have one on my 131" motor and it works great... No slippage...
I had the regular Pro Clutch and added TPP... Per John's (Rivera) advice... I also have the Rivera 66 tooth ring gear, 9 tooth pinion gear and Rivera Brute III Extreme Enclosed Primary Belt Drive...
1711tab is offline   Reply With Quote
Old 03-16-2010, 08:03 PM   #6 (permalink)
chriscalabro's Avatar
chriscalabro is on a distinguished road
wanted to bring this thread back to life to pass along my first impressions of the TPP on a pro clutch. When I had the bike dyno'd last year @ R&R and they added a Gold comp spring to my pro clutch. I had no problem with the extra effort but I could never get the clutch dialed in. It would always drag when it got hot etc. So I pulled the pro clutch out and replaced the clutch pack and went with a silver spring with the TPP. Huge difference as the clutch pulls in at low rpm as you would expect from a Rivera but it really locks up when you get get on it. I can actually find nuetral without the normal hunt and peck of the pasr. A highly recommended upgrade.
2007 HD FLTR (Road Glide)
R&R 117 Build
R&R Stage V billett Heads
R&R 615 Cams
Axtell 117 Jugs
Rinehart True Duals
HPI TB 55mm
Baker DD7
Baker +1
R&R internal Camplate
SE Performance Comp
(2) Jagg Oil coolers
Metzeler Rubber
Rivera Pro Clutch w/ TPP
chriscalabro is offline   Reply With Quote
