I have a 86 fxrc and I want to upgrade the trans to the splined shaft vs. the tapered ( I found out that it wont hold up to a good burn out). I have been told that there is a kit but I cant find it online. I do have a guy that has a splined shaft gear set off a 87 fxrt and that has to be the upgrade (I think)? If that is correct I need to know what clutch basket will fit. I know the starters changed in 90 so i dont want to go changing inner primary and starter. could I change the ring gear or the starter gear? any help would be fantastic or am i just
