Progressive Insurance
KomodoGear.comMotorcycle.comArnottAirRide360 Brake CompanyEagleRiderRosa's CycleAmericanMotorcyclistAssociationProCharger.comWheeldock.comMotorcycle.com Classifieds!Springfield ArmoryTech N' Cycle GearAdvanstarMotorcycleShows
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Transmission and Primary
Old 10-29-2008, 11:21 PM   #1 (permalink)
czissman is on a distinguished road
Inner primary mainshaft oil seal won't stay in!
98 Dyna Wide Glide
I've never seen this before. When I press the oil seal into the back-side of the inner primary cover and then remove the press, the seal begins to sort of... ooze... out of the case! Within a few minutes the seal will pop out all the way.
I've installed the seal with the side labeled "Oil Side" facing into the area where the primary chaincase lubricant will reside. I've compared this seal to the original and it seems to be the same dimensions.
Since the back of this seal floats in air (i.e., doesn't abutt another part), this obviously concerns me.
Any thoughts on why this is happening and how to correct it?
czissman is offline   Reply With Quote
Old 10-29-2008, 11:57 PM   #2 (permalink)
DDuess is on a distinguished road
I would try installing it dry after cleaning the seal bore with brake cleaner. (wow, rides a Harley AND eats lo-fat yogurt!)
DDuess is offline   Reply With Quote
Old 10-30-2008, 12:09 AM   #3 (permalink)
Thanks DDuess: I thought about cleaning / installing dry, but I'm concerned that over time the part may still vibrate out, since it seems to want to come out.
As it stands, if I put the seal in dry and it stays in, I'll be constantly worried about it coming loose until I know why it's wanting to come out in the first place, ya know?
lol... I thought someone would point out the yogurt!
Old 10-30-2008, 10:44 AM   #4 (permalink)
mlewis is on a distinguished road
I initially made the same mistake thinking I’d apply a little silicon seal to the oil seal; popped right out within a minute or so. Cleaned it all up nice and dry and reinstalled, no problem since.
mlewis is offline   Reply With Quote
Old 10-30-2008, 11:05 AM   #5 (permalink)
Excellent news, mlewis! I'll just clean it up, reassemble and see how it goes. Glad to find someone with the same experience so quickly!!!
Old 10-30-2008, 06:52 PM   #6 (permalink)
Inner primary mainshaft oil seal: should it seat completely?
Looks like I've resolved the issue of my seal not staying put, but now I'm concerned that it protrudes a bit from the back of the inner primary (about 0.04").
Is this normal?
Man, this seems like a bad design.
Old 10-31-2008, 10:12 AM   #7 (permalink)
SamF is on a distinguished road
install it dry...make sure it is fully seated...
SamF is online now   Reply With Quote
Old 10-31-2008, 10:17 AM   #8 (permalink)
that is not seated fully...are you sure you have the correct seal/part #
Old 10-31-2008, 10:22 AM   #9 (permalink)
GHOSTRIDER LIFE MEMBER
1711tab's Avatar
1711tab is on a distinguished road
if it's the correct seal installed properly it's flush... If it is the correct seal check to make sure the oil side of the seal is in the right direction...
"KING OF CUBES" - HYPERFORMANCE & R&R CYCLES R&D MONSTER 131" BUILD
INNOVATORS NOT IMITATORS
"YOU CAN'T SOLVE PROBLEMS BY USING THE SAME KIND OF THINKING YOU USED WHEN YOU CREATED THEM"...
1711tab is offline   Reply With Quote
Old 10-31-2008, 10:28 AM   #10 (permalink)
Alex93Sportster is on a distinguished road
I hope you are getting kickbacks from Yoplait for that free ad...
Alex93Sportster is offline   Reply With Quote
