» Buyers Guides |
10-13-2008, 12:35 PM
Loud primary
I have 8k miles on my 06 UC and the primary is very loud, sounds like a can of bolts churning around. Is this normal, I didn't notice it being quite so loud before. I am running Syn. Mercon V ATF in the primary. Is there something else better for that, or could something else be up?
Thanks,
Steve
2006 Candy Brandywine Ultra Classic
10-13-2008, 01:10 PM
Thanks,
Steve
Some o7's were noisy, and HD created a "fix" called the IDS for the final drive.
Never heard of anything on the 06's.
Might I suggest you use the recommended primary oil instead of ATF?
10-13-2008, 01:36 PM
FOG
The big "whatsit" nut coming loose in there? I can't remember what it's called, but not uncommon. CRS here....maybe someone else can remember the name.
trooper113
NRA Endowment Member
AMA Member
10-13-2008, 01:44 PM
Well, so far it sounds like I should pull the primary cover and check everything out for sure. Also get something different for primary fluid.
Is that the compensator nut that you're talking about maybe?
Thanks,
Steve
10-13-2008, 02:59 PM
FOG
Thanks,
Steve
That would be it.
trooper113
AMA Member
10-14-2008, 09:04 AM
Hopefully this weekend won't be raining, so I will be pulling the primary cover it looks like.
Thanks,
Steve
10-14-2008, 09:26 AM
FLHTCU Monkey
Check primary chain tension.
Check compensating sprocket nut.
10-14-2008, 09:42 AM
I guess that I should have done that when I changed primary fluid. Duh.... I was suspecting something was not good, and ran out of time to pull the cover and check things out. Haste makes waste I guess...
Thanks,
Steve
10-18-2008, 03:04 PM
Well, I got lucky no rain.
It looks like the chain was loose, had about 3/4" slack hot, not good.
I adjusted it to 1/2" which is right in the middle of recommended.
Filled it with Mobil 1 V-Twin 20-50 and it is really nice now.
Much quieter, smoother on the clutch engagement too.
Thanks,
Steve
10-18-2008, 03:10 PM
F$ck Google ads
I'll bet you found some wear marks in the upper part of the primary. Very loose chains eat into the aluminum. Makes a racket.......
2003 FXST gunmetal pearl
Revolution 107 "
Dewey's 107 heads @ 10.7
Andrews 67 G
SE CV44, SE a/c
Baker DD6
RB Racing 2-1 'Black Hole'
2008 FLHTCU dark blue pearl
103 "
Woods 6
SE a/c, TTS tuner
SE slip ons
After Douglas Adams RIP
10-18-2008, 03:55 PM
Yes, there were a few marks, fortunately I didn't put too many miles on it since it started getting louder.
Much better now though.
Thanks,
Steve
10-18-2008, 07:31 PM
dang,I wanted to be the heroe and tell ya to tighten the chain.but you beat me to it.really,thats what I was going to reconmend.and of yeah,did I mention amsoil?I love the stuff.
sick and tired of being sick and tired!
10-19-2008, 10:15 AM
That's ok, it got fixed, and you were right about the chain.
I would have picked up some Amsoil, but they didn't have it, so got the MB1 V-twin, I figured that should work pretty well.
Thanks,
Steve
