AdvanstarMotorcycleShowsMean City CyclesBikeBanditEagleRiderSpringfield ArmoryPerformanceOilTechTech N' Cycle GearRacerPartsWholesaleStoneyStraps.comHD PipesWheeldock.comProCharger.com
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Transmission and Primary
Daytona Twin-Tec
Old 10-08-2008, 08:59 AM   #1 (permalink)
dobain is on a distinguished road
Evo sportster 4spd clutch problem
I have a 1989 sportster 883 that has 6k miles on a 1200 conversion.
I picked up cheap, was told the clutch plates were wore out... test rode it, yep shot.
I replaced the friction plates, and one burnt hard plate, and replaced the diaphragm spring. adjusted the clutch and fine tuned with the "new" clutch cable.
Problem;
Test ride shows the same problem exist, just not as bad. if you do a roll on it over powers the clutch, it's worse in second gear.
Is there a common problem with the clutch system, do the baskets need replacing often?
dobain is offline   Reply With Quote
Old 10-08-2008, 09:04 AM   #2 (permalink)
baggersport's Avatar
baggersport is on a distinguished road
Replace ALL the steel plates.
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote
