StoneyStraps.comKomodoGear.comCycleGear.comDaytona Twin-TecHD PipesCrystal-GloPro PadKewlMetal.comCheapCycleParts.comCellino&Barnes Motorcycle Attorneys
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Transmission and Primary
Tech N' Cycle Gear
Old 10-05-2008, 06:09 AM   #1 (permalink)
Mad Fred's Avatar
Mad Fred is on a distinguished road
What tranny is this?
Can someone tell me what tranny this is ??
Mad Fred is offline   Reply With Quote
Old 10-05-2008, 10:11 AM   #2 (permalink)
Pebble Cruncher
Rockbiter's Avatar
Rockbiter is on a distinguished road
well, its on a shovel, so its prolly a four-speed, unless he's installed one if the Baker 6into4 setups...
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote
Old 10-05-2008, 10:15 AM   #3 (permalink)
springer-'s Avatar
That's a kick start only 4 speed ratchet top.
207-242-8374 Cell Phone
207-621-8089 Port Shop/Dyno Shop
Old 10-05-2008, 10:27 AM   #4 (permalink)
Pamagajo is on a distinguished road
Ratchet Top
It's the best Tranny H-D ever made! The 4 speed ratchet top as the previous poster said. Depending on whether yours has the aluminum "ears" on the clutch end, it could be either electric, or kick start. If you don't have those ears, then it's kick only. Looking at it from the clutch side with the primary cover removed, if it has two aluminum bosses, each with two bolt holes (for an aluminum primary cover), then it will support electric start (FXE) if those aren't there, then it's kick only (FX).
Pamagajo is offline   Reply With Quote
Old 10-05-2008, 10:40 AM   #5 (permalink)
springer-'s Avatar
Based on the picture, in the area under the chain where the "ears" would wrap around the swingarm pivot, it looks to be a kick start only. Hard to tell because the picture is dark in that area. If you use a flashlight and look in from the angle and side of the picture above, look for part of the transmission case wrapping around the end of the swingarm pivot.
Old 10-05-2008, 10:47 AM   #6 (permalink)
Mad Fred's Avatar
Oki!!
Thanks for all the great answers! Its a 4speed 1gear up 2-3-4 down..
Should the speedometer be attached to the tranny? I dont have one for the moment..
//fredrik
Old 10-05-2008, 10:53 AM   #7 (permalink)
springer-'s Avatar
If it is a FL type tranny it could have a speed drive. The speedo drive would be located behind the exhaust in your picture. Can't tell from the picture, you would have to look at it.
Here is an example with a speedo drive. It is the threaded 3/4" round piece coming out of the tranmission case at an angle on the right side.
Old 10-05-2008, 10:53 AM   #8 (permalink)
Mad Fred's Avatar
Here is a picture from the other side..
//fredrik
Old 10-05-2008, 11:21 AM   #9 (permalink)
Mad Fred's Avatar
I have been out and looked at my bike, yes i have the speed drive..
Old 10-08-2008, 09:37 AM   #10 (permalink)
Mad Fred's Avatar
Can anyone se if there is a kickstart only or a electric start on this picture..
//fredrik
Old 10-08-2008, 09:50 AM   #11 (permalink)
springer-'s Avatar
That transmission has the casting directly below the chain in that picture. That indicates it can be used with electric start. In your case it is not currently setup for electric start. To install electric start would require replacing most, if not all, of the primary parts (assuming it doesn't have a ring gear or electric start inner primary) as well as adding all the electric start pieces. The oil tank would also require replacement. Another option would be an electric start belt drive primary.
