There should .100" of space behind the bearing race. There is a puller to remove that race.
Here is the problem, the puller will not work if the race is on all the way to the output shaft on the tranny. There is suppose to be about .100" of space between the race and the output shaft (5th gear) where the seal. If there is no space, you can to cut it off using a cut off wheel.
This is a puller that we made but JIMS sells one just like it and it works exactly the same as I am going to show you. When you use the puller, place a thick hardened washer between the forcing screw tip and the main shaft end so the tapper on the forcing screw doesn't damage the main shaft end.
You can see it has a thin lip to fit behind the bearing race.
I put a sharpie mark on the main shaft to simulate the end of the gear. If you can fit this type of puller, I would recommend you buy one.
As I mentioned earlier, the race can "walk" up the shaft and sit right up against the gear. If this happens and you can't fit the puller behind the race, you can cut the race off using a tool like this.
I would first try to cut a slot on each side just deep enough to fit the puller into the slots and then use the puller, indicated with the sharpie marks on the side of the race. BE CAREFUL NOT TO CUT TO DEEP, you don't want to damage the shaft.
Another way is to cut the race off at an angle. You cut at an angle so the gear doesn't interfere and so you don't damage the gear with the cutter. You may not be able to get the last little bit of race with the cut off wheel, you can use a chisel and break the last part. BE CAREFUL NOT TO CUT TO DEEP. You don't want to cut into the main shaft if you can help it. If you do nick the shaft, don't worry to much, you can dress it with a light sand paper.
I would Double Check to make sure it is up against the gear, it may just look like it is too close to use the puller but you only need .100" clearance to fit the puller in.
