IMJ~~~
Are you familiar with Service Bulletin M-1161?
This service bulletin addresses the "improved" starter jackshaft lip seal HD# 12066A. It tells how to install it....your local dealership should be able to print you up one.
Also are you aware of Service Bulletin M-1148?
Which deals with a NEW Inner Primary Mainshaft Oil Seal Change which is HD# 12052A. Since you are at the location of the "Jackhaft Lip Seal you might as well be replacing this one as well. Once Again your local HD dealership will be able to print up this Service bulletin as well.
Also....another note....since from what I am reading I sense what you are doing.....once you remove the inner primary, make sure you REMOVE all of the SILICONE from the bolt holes that have silicone in them or on them. I replaced with Napa black high temp RTV silicone on each bolt that had it previously as well as the bolt hole. I used a tappit to remove the old silicone out of the bolt hole threads as well prior to adding new silicone. Remember that silicone does not adhere to old silicone. I also cleaned the entire inner primary while it was out with electra contact cleaner by CRC. Take your time....do it out side that silcone will get everwhere when it starts to come off....it can be very frustrating to get it all off of the inner primary but you have to.
Regards,
"Classic"
