Dan Vance RacingAmerican Side Road Cycle
BikeBanditCycleGear.comSportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.comCustom Dynamics
Old 05-14-2008, 05:14 PM   #1 (permalink)
03fxdl100th is on a distinguished road
Question Removing shifter shaft from mid controls
I just installed a set of extended forward controls on my lowrider. The setup came with a beauty cap to put over the shaft that goes through the primary. I just don't like the look of having the shaft still stick through the derby cover (I think that's what it's called). I asked my service guy if it could be removed so it could look like the wide glides and he said something about having to take off the inner primary.
So my question is how difficult would this be to do? I consider myself mechanically inclined, but the only experience I have working on motorcycles is installing my forward controls and removing my mids, so would this be something you guys think I could tackle on my own? I can enlist the help of some of my friends that are experienced on bike maintenance if I get stuck along the way.
03fxdl100th is offline   Reply With Quote
Old 05-14-2008, 06:30 PM   #2 (permalink)
Fourcats's Avatar
Fourcats is on a distinguished road
...Live with the "beauty cap".
Fourcats is online now   Reply With Quote
Old 05-14-2008, 07:43 PM   #3 (permalink)
P.S. I also posted this in the dyna discussions forum.
Old 05-14-2008, 10:06 PM   #4 (permalink)
tguil
Originally Posted by 03fxdl100th View Post
... I consider myself mechanically inclined, but the only experience I have working on motorcycles is installing my forward controls and removing my mids, so would this be something you guys think I could tackle on my own? I can enlist the help of some of my friends that are experienced on bike maintenance if I get stuck along the way...
I'm mechanically inclined too, but I had a tech at the dealer do the job for me. IMO it's worth the bucks to get rid of the "beauty cap". I don't get a kick out of doing my own work any more.
Tom
Two Harleys and a Dodge Hemi -- life is good.
tguil is offline   Reply With Quote
Old 05-14-2008, 10:18 PM   #5 (permalink)
Longtime Asphalt Cowboy
Texan's Avatar
Texan is on a distinguished road
My first question is do you have a service/AIM manual for the bike? You're going to pull the out and inner primaries. This means removing the clutch basket, the compensator sprocket and primary chain and the inner primary. Removing the starter is one of the first steps. I'd guess by you user name the bike is a 100th Anniv...so probably wouldn't need a new primary chain.
You're going to need a banjo gasket, inspection cover gasket and primary gasket.. Also going to need a stator O-ring gasket. I'd also, beings you going to be in there, I'd replace the out put seal on the transmission...little $3.00 part that cost $300 or so down the road. And a quart of Amsoil ATF Super Shifter fuild.
Also, inspect the transmission shifter lever and lock bolt. This little bugger gets loose and either falls out or ruins the spline on the shifter collar. Replace the whole lever and bolt.
You're going to need larger sockets for removing the primary drive train...
Taking your time it's a pretty straight forward 3 hour job...But you need a manual....got it ..... GO FOR IT!!!!
o~\o
Texan is offline   Reply With Quote
Old 05-14-2008, 10:20 PM   #6 (permalink)
WS6 Formula's Avatar
WS6 Formula is on a distinguished road
Removing the original shift shaft lever
Get a hacksaw blade and tape each end with duct tape, leaving about two inches exposed in the middle. Also put some duct tape on the primary and cylinder cooling fins. Tape a wrench on one end to get a better grip (on the end of the blade so as you pull on the wrench you will be on the cutting stroke of the blade). Slip the blade between the primary and engine from the bottom of the bike with the wrench end on the bottom. Position the shaft so you can cut about a quarter inch from the lever (not in the welded area). Use your other hand to guide the top of the blade as you cut. After cutting through, the shaft will slide right out, and the lever will just fall to the floor.
Cover for the original shift shaft lever hole
I used a chrome carriage bolt http://www.chromebolt.com/51618-x-13...olt-p-845.html, and put a two inch piece of rubber hose on the threads then added some shrink sleeving on the hose to get a nice snug press fit into the empty shaft hole. If you have a black primary: paint a unplated carriage bolt. Aluminum cover: scotch brite a chrome carriage bolt.
Larger photo: http://tinyurl.com/5jtrup
2006 Dyna Low Rider
Dragonfly Green Pearl & Vivid Black
Photos, Modifications & P/N's:
http://tinyurl.com/o3n3sf
WS6 Formula is offline   Reply With Quote
Old 05-17-2008, 06:10 PM   #7 (permalink)
WS6, if I use your suggestion would I be able to just get a new blank cover like there is on the wide glides? My bike has a cover where the old shift shaft went into that is held in by 4 screws.
Old 05-17-2008, 07:19 PM   #8 (permalink)
I'm not familiar with the earlier primary's, but I think you would be able to use an inspection cover without the hole in it, you just need to plug the inner primary through hole. Maybe just cleaning out the inner primary through hole and filling it with high temp silicone.
Old 05-17-2008, 08:00 PM   #9 (permalink)
Do you think that would be do-able without removing the primary?
Old 05-17-2008, 08:54 PM   #10 (permalink)
Iron Butt, SS2000
jerry34208's Avatar
Hey, nice Dyna.
Now if only I could learn to ride worth a sh!t...
Old 05-18-2008, 09:24 PM   #11 (permalink)
Yes....Once you pull off the inspection cover, you should get an idea on what you need to do.
Originally Posted by jerry34208 View Post
Hey, nice Dyna.
Thank You........
Old 05-20-2008, 08:35 PM   #12 (permalink)
Excellent thank you very much ws6
Old 04-22-2009, 12:45 PM   #13 (permalink)
footballhi is on a distinguished road
03fxdl200th: how did the saw job work for you ,i need to remove mine as well. i have the cover with no hole. but how do you plug the other side?
footballhi is offline   Reply With Quote
Old 05-10-2009, 06:37 PM   #14 (permalink)
1M$man is on a distinguished road
Dont try to do this. It will be a disaster since you can not understand WS6's explicit, simple directions. This leads me to believe this. I am usually right about these things Sorry. That's my take. I dont mean to be disrespectful. Just dont try it at home. It will be a mess. But not to worry...
Copy the instructions with a printer and show them to a good friend or shade tree mechanic. The time and labor involved are minimal.
WS6 Formula wrote explicit complete and very easy to follow instructions. His way works incredibly well. There is absolutely no reason to go to the great expense of removing everything.
We did it on my bike WS6 Formula's way.Our plug method was different (his way is just fine) but it lasted 8 years until i had the inner primary chromed. We welded the hole at that point.
1M$man is offline   Reply With Quote
Old 05-10-2009, 09:59 PM   #15 (permalink)
spgtti is on a distinguished road
You meant to be disrespectful,that was the point of your post. The later primarys don't have an inspection cover and the directions could've been about plugging the outside hole. Asking about the inner side was a valid question. You're a million $ Ahol IMO.
spgtti is offline   Reply With Quote
