Originally Posted by Marty59
Not to highjack your thread - I just removed the solid gasket that came with my flame clutch cover. My local indy sold me a ring style gasket (i think it's made by cometic?)- saying that the MoCo just went back to the ring versus solid gasket. Is that true? Is there an advantage to one over the other? I don't want any leaks.
Not a highjack, the reason I ask about weather or not to remove the center of the new style clutch cover gasket is:
1.) My gasket does not have a perforation to "punch out" the center material (marked with this side toward clutch). Being a solid gasket, rather than a perimeter gasket would mean that the primary oil would not be able to get to the back (outer) side of the gasket. This would mean the gasket could only develop a leak from the inner sealing surface, rather than both sealing surfaces.
2.) I was doing a search on the VPC clutch, and found a Tech. article on the installation of the variable pressure clutch. In the article (with pictures) they were using the new style clutch cover gasket. In one of the pictures they show the new style gasket. In that picture, it looks to me like the gasket center part could be removed. The pic is vague and subject to interpretation. The picture makes it look as though the gasket was cut or perforated from the factory for easy removal of the part marked "this side toward clutch".
3.) With the VPC clutch installed, I could see the need for the center portion of the gasket being removed, for clearance.
Back to my original question.... is this center portion of the clutch cover gasket marked "this side toward clutch"
intended to be removed before installation?
I already have the new style gasket on my outer primary cover, and it has stopped the seepage I always had with the "old style" gasket. I like these new style gaskets, and I am sure I won't have any leaks. I just dont know for sure if the clutch cover gasket is supposed to be installed
after removing the center portion of the gasket.
Thanks for the replies.......Tech23.
