ProCharger.comPowersportModels.comSoCalCoversAvonTyresLawTigersMotorcycle.comUpbeat AudioBikeBanditWheeldock.com
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > General Discussion Forums > Touring Motorcycle Family General Discussions
EagleRider
Old 05-18-2008, 01:09 AM   #1 (permalink)
rdf385 is on a distinguished road
3M Clear Bra ???'s
Anybody have any experience with the 3M "Clear Bra" on their scoot? Any info would be appreciated.
rdf385 is offline   Reply With Quote
Old 05-18-2008, 01:24 AM   #2 (permalink)
PR3VS56's Avatar
PR3VS56 is on a distinguished road
I know a lot of guys use them on muscle cars. Where would you use it on the bike?
'05 FLTRI
K&N, SERT, 95" Dave Mackie Mega-Sphere, Feuling oil pump & LMR-002 (Baisley) spring, S&S Crank, S&S Roller Rockers,
black SuperTrapp SuperMeg 2:1 (19 disc closed cap), RIVERA PRIMO Pro-Clutch, SE 6-Speed, Ride-Str8, heated grips
Pri: Amsoil Syn ATF. Trans: Redline Heavy ShockProof. Crank: Redline 20W60HD
105tq/107hp
Proverbs 3:5-6
Fruit of the Spirit
PR3VS56 is offline   Reply With Quote
Old 05-18-2008, 06:48 AM   #3 (permalink)
brownjams is on a distinguished road
I haven't use the product but on another forum read quit a bit about them. I was thinking of getting 3m for my new scoot. They come precut in 3 pieces for the fairing or you can save some cash and buy a roll which would involve making a pattern and cutting to fit. you might try doing a search on google using "3m hd forum".
good luck, ride safe and sober.
brownjams is offline   Reply With Quote
Old 05-18-2008, 09:16 AM   #4 (permalink)
izzi mike's Avatar
izzi mike is on a distinguished road
http://www.pro-finish.com/orderhawg.html
06X
izzi mike is offline   Reply With Quote
Old 05-19-2008, 12:05 PM   #5 (permalink)
I have an '08 FLHT and am considering the Clear Bra for my fairing, front forks, frnt fender , gas tank and saddle bags.
rdf385
Old 05-19-2008, 12:15 PM   #6 (permalink)
racerdave's Avatar
racerdave is on a distinguished road
I've been thinking about doing my saddle bag lids. RD
Proud supporter of the SaintLouis Cardinals. More World series titles than any other National League team.
racerdave is offline   Reply With Quote
Old 05-19-2008, 12:29 PM   #7 (permalink)
Custom Painter
kustom_flames's Avatar
Well they are clear...not necessarily 'invisible'. I would think cutting your own patter might be a bit tricky, especially with all the curves to deal with.
Stuff is similar to what they use on the newer HD rear fenders (under the pass. seat) and that little area on the side covers of touring bikes.
Old 05-22-2008, 03:26 PM   #8 (permalink)
h2oskier66067 is on a distinguished road
I had the stuff on my car and it works great, but it is not invisable, especially on
certain colors. Our car was a medium metalic blue and not visable until you got
within 5 feet. The film has a slight orangepeel look. Not bad, but it is there if you
look. I really does what it is suppose to do. After 3 years there were no rock chips
but just past the line on the hood it had a few chips.
I hope this helps.
Dave
h2oskier66067 is offline   Reply With Quote
Old 05-22-2008, 04:30 PM   #9 (permalink)
omgtkk is on a distinguished road
I have a bulk roll that I bought off Ebay. It's great stuff and is 'nearly' invisible from more than a foot away if you keep wax residue out of the edges of it. One big caveat though; this stuff is very tricky to install. If you are thinking about putting it on a surface that has compound curves, you are in for a very rough time. Even something seemingly as simple as the top surface of the rear fender can be a major PITA. I wouldn't even consider trying to install it on a fairing front by myself. Let a pro do it. Saddlebag lids and front surfaces would be pretty easy.
Just my 2 cents.
omgtkk is offline   Reply With Quote
Old 05-22-2008, 04:49 PM   #10 (permalink)
Custom Painter
When installing....does it say to mist the substrate with soapy water so you can move it around a bit and get it into place? Or leave it in the sunlight to make it softer and more pliable?
Those are some things that can help on the install....
Old 05-22-2008, 09:45 PM   #11 (permalink)
Cummins is on a distinguished road
The recommendation is a 25% alcohol / 75% water mix. Allows for the film to be moved then evaps quickly without soapy film.
Love the clear bra. Had it on my Bike in 2005 when I rode it to Alaska, when I return I pulled it off. Clear bra was slightly damaged, bike looked new, NO damage.
Cummins is offline   Reply With Quote
Old 05-22-2008, 11:07 PM   #12 (permalink)
Are we having &quot;FUN&quot; yet??
Jeffytune's Avatar
I just want to state for the record that I for one am in favor of clear bra's, mostly on 18-24 year old gals.
I'm Just Sayin'...
2007 FLHT 96 CID W/IDS drive
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
93.25 Torque 78.74 HP
Professional Rockat Surgen
Disclaimer.
I do not work for Vance and Hines, I just like there stuff. Any suggestions I make are to be use at your own risk.
Old 05-23-2008, 02:50 AM   #13 (permalink)
timbo141's Avatar
timbo141 is on a distinguished road
I haved used ArmorCoat which is easy to apply but needs to be sprayed. Great product!
http://armorcoat.armorauto.com/
timbo141 is offline   Reply With Quote
Old 05-23-2008, 03:00 AM   #14 (permalink)
F$ck Google ads
ViennaHog's Avatar
My kind of protection is a thick layer of road grime accumulated over thousands of miles. ...............
2003 FXST gunmetal pearl
Revolution 107 "
Dewey's 107 heads @ 10.7
Andrews 67 G
SE CV44, SE a/c
Baker DD6
RB Racing 2-1 'Black Hole'
2008 FLHTCU dark blue pearl
103 "
Woods 6
SE a/c, SERT
S&S SPOs
After Douglas Adams RIP
ViennaHog is online now   Reply With Quote
Old 05-28-2008, 03:53 PM   #15 (permalink)
Vendor
ProFinish's Avatar
ProFinish is on a distinguished road
I sent you a pm regarding the 3M paint Protection Film.
"CLEARLY THE BEST IN H-D PAINT PROTECTION FILM"
925-200-8556
ProFinish is offline   Reply With Quote
