» Buyers Guides |
04-25-2008, 06:36 PM
#16 (permalink)
Average Dude
So it will cost you an extra buck to fill it up. Are you shiiitting me?
If the manual calls for 91, then use 91 or higher.
Deut. 23:12-13
04-25-2008, 09:07 PM
#17 (permalink)
ASA Lives
Originally Posted by ScooterShooter
I was just about to roll out my 08 EG Classic last week when the salesman said to use ONLY premium fuel. Well, that makes since, however my dream of saving on fuel prices with the better milage than my cage went out the window. The manual suggest 91 octane.
I want to keep my scoot in top notch. What do you say?
91 is Premium in the western US.
nuqneH
Now ride Ultra  (Modified) But still Ultra.
 Ride Safe
04-25-2008, 09:28 PM
#18 (permalink)
87 unless it's 90 degrees. Harley has to account for all conditions in the states and with 9.3 compression stock, if it has no ping the bike doesn't know the difference.
00 Fatboy with all the trimmings
07 Ultra for the real riding
25+ years ASE Master Auto Tech
04-25-2008, 11:19 PM
#19 (permalink)
Yes, it does know the difference. Do a dyno run with both, then say that. Also look at the carbon buildup comparison and then tell me that.
06FLHRCI
Baker DD6
Baker +1 oil pan
BAKER FUNCTION-FORMED™ FL OIL SPOUT
Doherty PACC/Power vents
Fueling Oil Pump
Harley 95" flat tops
Harley roller rockers
SE Forged Rocker Support Plates
Heads CNC'd by NRHS
Odyssey Battery/Charger
Reinhart true duals
S&S 510-G Cams
Sta-Bo bushings
ThunderMax w/auto tune
04-26-2008, 05:32 AM
#20 (permalink)
Average Dude
And if you could see knock sensor activity.....But, then again, its not my bike. I think subjecting a 20k bike to the abuse of low octane gas just to save a buck on a fillup is a dumbass idear.
Deut. 23:12-13
04-26-2008, 08:13 AM
#21 (permalink)
when I got my bike built up to 95 inches the builder told me I could run 87, he said it performed better = burns faster= I never had much success with it not pinging but that's what I was told.
04-26-2008, 08:17 AM
#22 (permalink)
top tier fuel only for me
Originally Posted by harleymike77
 Ditto here......... (like Bountyhunter mentioned = Sunoco - 94)
http://en.wikipedia.org/wiki/Top_Tie...rgent_Gasoline
04-26-2008, 08:27 AM
#23 (permalink)
Is anyone using additives?
SCOOTER SHOOTER
Ride Well, Ride Safe, Ride with God
2008 EG Classic Vivid Black
04-27-2008, 07:12 PM
#24 (permalink)
That's what I hear.
Course I hear the opposite - high octane will cause carbon build up, switch a few tanks.
It's all magic I tell 'ya - what to do, what to do?
04-27-2008, 09:24 PM
#25 (permalink)
I've taken plenty apart with only premium use and have tons of carbon. There is not enough additives in most brands of fuel to clean very well. I use some injector/valve cleaner a couple times a year. I don't drag race my bagger and the knock sensors are doing what there suppose to. I do use premium in my fatboy cause it's not stock and ride it hard and doesn't have knock sensing capability.
04-27-2008, 10:03 PM
#26 (permalink)
I agree with YankeeBob, you spend 20+K on a bike with a five gal tank and your worried about 25 cents a gal ? Maybe you shoulda bought a moped
06 Street Glide, 95",Andrews 37G cams, ported heads, Wiseco flat top pistons, SE 44mm carb,SE Ignition, SE Slip-ons. 06 FJR for GRINS
04-27-2008, 10:29 PM
#27 (permalink)
Bike gets 40 mpg, high test fuel @ $3.999, 200 miles = $20.00
4 wheeler 13.33 mpg, reg fuel @ $3.459, 200 mile = $51.89
Bike saves dough, savings = $31.89
I say run 91 octane and ride as much as possible!
2BRNR
04-27-2008, 10:47 PM
#28 (permalink)
All motor manufactures have and octain rating for each engine they produce. This is used to prevent premature detation or in other words spark knock that can cause major engine damange. A motor that does not pre denoate with 89 octain will not run any better using 93 octain. With this being said yes even using 91 or 93 in my 05 classic it will at times spark knock. esp. sitting in traffic ect. It is an air cooled engine there for difficult to controll temp and there for the grater chance of pre denation that is just one reson Harley recommands 91 or 93. there are several other reasons compression. timing. leaner fuel ratios to meet epa regulations ect. It is not about making the bike run better but to help it from coming unglued.
04-27-2008, 10:48 PM
#29 (permalink)
fuel
I run 87 octane only when in the sticks where it is that or diesel choice is clear then.
2004 Superglide
95 inch 10.5-1 JE pistons
Branch #4 heads with compression releases
Andrews T55G gear drive cams
Jims roller rockers
Feuling superpump and lifters
DTT TC88A ignition
Mikuni HSR45 carb with 3 inch filter
S.E. adjustable pushrods and tubes
S.E. high tensile cylinder studs
Barnett scorpion clutch
S.E. 2-1 pro pipe with home made baffle
Progressive fork springs and 11 inch black 412's
Sputhe Positrac
Vulcan Mid-glide trees
Headwinds carbon fiber headlight
04-27-2008, 11:54 PM
#30 (permalink)
how much will you save????
I agree. Won't go low to save money and ruin the engine. How about a mid grade occasionally?
Only save 50 cents or so per tank, not worth messing up engine.
