Need Help With Sportster : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Sportster/Buell Engine
Old 02-13-2017, 03:47 PM   #1 (permalink)
txcannonballer wants to know Dino or Syn?
The bike quit running in the middle of a ride, about 30 min into the ride, no smoke or anything. Got the bike home, tried to start it, engine turns but all it does is back fire.
-1993 Sportster 883
-Battery is fully charged, and the starter is cranking the engine at a normal rate.
-pulled the plugs, they are getting spark
-Carb is getting fuel, I even pulled it apart and cleaned it to be sure, and can verify that the carb is working.
-also checked compression, its with in spec
I am all out of ideas, thanks for your help
txcannonballer is offline   Reply With Quote Quick reply to this message
Old 02-13-2017, 04:20 PM   #2 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne just installed tassels Thermodyne just installed tassels Thermodyne just installed tassels
Fuel, compression, timed spark.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 05:51 AM   #3 (permalink)
FXDRYDR is still riding a stock bike FXDRYDR is still riding a stock bike
Had similar issue. Bad ignition module. Replaced CPS, wires, plugs, coil for good measure.
FXDRYDR
2003 FXD
124
Black, chrome & loud.
