sportster cam position sensor removal and can gear install : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Sportster/Buell Engine
Old 11-17-2012, 01:16 AM   #1 (permalink)
Krowbar wants to know Dino or Syn?
My brother in law removed his cam cover on his 2003 sportster to get powder coated and we're not sure how to remove the cam position sensor without cutting it. Does it disconnect somewhere? Thanks
1985 FXRS: Dyna 2000 ICM, Twin Tec II Single Fire, Mikuni HSR 42mm carb, S&S intake, Progressive 11.5" rear springs, progressive front sprigs, SPF Lightningheader exhaust and bars, rebuilt front forks with brace (lowered back to 25.5"), Arlen Ness fairing, all new electrical, shyt-ton of powder coating etc. etc.
Krowbar is offline   Reply With Quote Quick reply to this message
Old 11-17-2012, 02:05 AM   #2 (permalink)
I guess it is the crank position sensor. It routes through the cover, and not sure how it disconnects.
Thank you!
Old 11-17-2012, 02:22 AM   #3 (permalink)
Figured it out.. Thanks
Old 11-17-2012, 02:24 AM   #4 (permalink)
Well the crank position sensor, Need to make sure we install the cams correctly.
