883/1200 : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Sportster/Buell Engine
Old 09-20-2009, 12:09 AM   #1 (permalink)
harley-kid's Avatar
harley-kid wants to know Dino or Syn?
883/1200
what do ya guys think the best conversion kit is? or send out cylinders bore them out etc???
harley-kid is offline   Reply With Quote Quick reply to this message
Old 09-20-2009, 07:31 AM   #2 (permalink)
have your bored, talk to headguy, as you will need dished pistons.
Old 09-21-2009, 06:36 AM   #3 (permalink)
Very good power gain.
With reverse-dome pistons, the OE compression is maintained.
With a flatop, use a set of Andrews 8 cams and hang on!!
Scott
Old 10-16-2009, 10:41 AM   #4 (permalink)
VRSCR's Avatar
VRSCR wants to know Dino or Syn?
Scott, Who's pistons would you use? If using the #8 Cams, can you just bolt the stock 883 heads up with out modifications?
Home of the 9 second street ridden 1130cc VRod
NOTICE: Info I post may be correct and relevant to threads posted in. Yet I may have learned this info else were and am just sharing it in a public forum for other members benefit. I am not responsible for any tantrums or fits you may have because it was read else were on the world wide web!
HIGH SPEED, LOW DRAG MOTHER *UCKER
VRSCR is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 07:58 AM   #5 (permalink)
Wiesco offers a flat top.
Should still run good without head mods.
You will need an ignition either way you go.
Scott
Old 10-19-2009, 08:43 AM   #6 (permalink)
VRSCR's Avatar
What advantages are upgrading the ignition?
Old 10-19-2009, 08:58 AM   #7 (permalink)
Premium octane member
TXCHOP's Avatar
You have to change the ignition to an adjustable(tunable) type unit to compensate for the extra compression and not have any detonation...
Fwiw, i did one of Hillside 883-1200 conversions last year. N8 cams, flat top wiseco's, Hillside changed valve in the heads,dtt ignition, cycle shack slip ons and s/e a/c, rejetted.....One of the most fun bikes i have built and ridden.....ever....Every time i service it for the owner, i ask if he wants to sell it....he won't...
S&S T124
Old 10-24-2009, 10:53 AM   #8 (permalink)
hightop's Avatar
hightop wants to know Dino or Syn?
Somewhat off topic, but last week I worked on an older 883 that needed a top end, valve job, oversize pistons etc., and couldn't talk the customer into converting it to a 1200. Ended up going to .005" over pistons.
Now over the years I've taken off and re-installed quite a few top ends for gaskets and such without going bigger, but this is the first time I can remember putting on the torque plates and not going bigger, and it kind of bums me out to leave all that power on the table when I was right there, even though after the road test I'll probably never ride the bike again.
Anybody out there that works on bikes for a living know what I'm talking about, or do I have a screw loose?
Now I've got an '05 TC88 apart for valve seals, and the customer doesn't want to do anything extra either. STUPID ECONOMY!
hightop is offline   Reply With Quote Quick reply to this message
Old 10-25-2009, 09:36 PM   #9 (permalink)
Karsten wants to know Dino or Syn?
Mine is most like about as old a 883/1200 convsersion as you can get using Buell/Thunderstorm parts.
My 1998 883/1200 was done years ago by the original owner so I haven't a clue but is fast.
Buell 1200 Cylinders
Buell 10.0:1 pistons
Buell Thunderstorm Heads
Screaming Eagle cams
Screaming Eagle Ignition and coil
Screaming Eagle A/C with K&N Lifetime Filter
Screaming Eagle jet kit
Vance & Hines 2 into 1 Pro Pipe
Progressive 11 1/2 inch shocks to keep the front tire on the ground.
It took 3rd place in the AMI Brute HP Shootout in he 1200 V-Twin class at Daytona back when he was a student there.
I was told it will redline at 7000 RPM but I don't want to find out myself.
Has some 80 plus HP at the rear wheel.
Karsten
Karsten is offline   Reply With Quote Quick reply to this message
Old 10-26-2009, 01:55 PM   #10 (permalink)
VRSCR's Avatar
I just did a 1999 1200. Used N2 cams, DTT ignition(single fire), Mikuni 42 w/high flow air cleaner, Bassanii pro street exhaust(customer had to have) Pulls the front wheel up shifting into second. Seems pretty quick. I am guessing 70-75hp. Will have it dynoed next week for hp numbers.
My ole'lady has a 1200 with all the Buell tricks and a Supertrapp 2 into 1. I want to compare the two dyno numbers.
My buddy is going to be pissed if the ole ladys bikeis higher hp.
Old 10-26-2009, 05:45 PM   #11 (permalink)
forget the numbers, your buddy will be more pi$$ed when he gets beat by a girl!
