RRcycles.comAmerican Side Road CycleJekillandHyde.euDiamond Bar ChoppersBub EnterprisesDan Vance RacingMotorcycle.comMotorcycle.com Classifieds!MBO Enterprises
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Sportster/Buell Engine Technical Discussion
Old 09-17-2009, 03:58 PM   #1 (permalink)
jevinger is on a distinguished road
top end questions
Hi, i have a few questions for anyone that can help me. I have a 97 sportster 883 with a 1200 big bore kit in it. i was riding and noticed exhaust starting to come from the rear left head bolt. It was loose. I took the rocker box off and retorqued all head bolts. It still did the same thing. I now have the head off and the head gasket is blown at that cylinder stud.
My question is when i go to order new gaskets does the thickness really matter? And what brand, and gasket material should i get?
Also, I will be pulling the cylinder off to put a new base gasket on and to inspect that 1 cylinder stud to see if it came loose for a reason and the gasket blew after it was loose. Do I have to use new piston rings or can i get away with putting the gasket down and the cylinder back on with the same rings and without worrying about rehoning the cylinder
jeff
jevinger is offline   Reply With Quote
Old 09-17-2009, 04:57 PM   #2 (permalink)
you can reuse everything . since the head is off replace head gaskets with metal reinforced gaskets (mls) (est) they'll be able to handle the compression - stock gaskets just won't do.
Old 09-17-2009, 10:26 PM   #3 (permalink)
aka_matt is on a distinguished road
yes, thickness matters... it will change ur comp ratio...
Matt
FOR SALE
aka_matt is offline   Reply With Quote
Old 09-18-2009, 12:29 AM   #4 (permalink)
Thanks for the advise. Are you talking about the cometic gasket sets? what about the gasket thickness? would it be a problem with different thicknesses for the lifters and rods or do they adjust and it is no big deal?
Thanks again.
Jeff
Old 09-18-2009, 12:38 AM   #5 (permalink)
i measured the old head gasket i took off with a caliper and get .04 to .045 . Can you suggest the right brand of gasket to get. I could only find the cometic est to come in .03 for that type of gasket in 1200 in my jpcycle catalog. Does the small difference in height make a large difference in compression and would it be a big factor in longer term engine life/performance ?
Old 11-04-2009, 04:08 PM   #6 (permalink)
Iron Will
Hillside's Avatar
That .030" gasket will be fine. Run it.
Scott
