Originally Posted by nauticaee
I need some help! all my gears in my engine fell out when i took the side cover off so i was wondering i know i have to take the rocker covers off to raise the push rods but when i do that, do i just line all the timing marks up with the number 1 at tdc? if at all possible can some one send me a picture or a copy from the manual i need ot get this back up asap thanks.
The book would help a lot, and I don't have one anymore. And yes, all you have to do it line up all the dots again. Make sure you start at the pinon (motor shaft). It's all easy don't worry. You might have to slide two in at a time though. Good luck....
It's a machine, it's fixable. Unlike a woman.......
If it's "right", fix it......if it's "wrong", milk it as long as you can......
