JekillandHyde.euAmerican Side Road CycleSportbikeTrackGearMotorcycle-CommunicationDan Vance RacingRRcycles.comCycleGear.comPro Pad
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Sportster/Buell Engine Technical Discussion
Bike Bandit
Old 04-11-2009, 01:59 PM   #1 (permalink)
Ares is on a distinguished road
Help with Harley Sportster 85', 1000cc's
I am having a few problems.
Sportster is starting to backfire.
Chain is drooping.
When I checked out pricing at local Harley they pretty much said it would be 1k to get everything done for chain. Backfiring is a recent problem.
If I knew what I was doing I am willing to try and fix these things myself.
Ares is offline   Reply With Quote
Old 04-11-2009, 02:10 PM   #2 (permalink)
Dave63's Avatar
Was the guy telling you this wearing a mask and holding a gun?
Dave
Old 04-11-2009, 04:51 PM   #3 (permalink)
eagle56 is on a distinguished road
If you have a chain drive that cant be to hard to either adjust or renew.
the dealers quoting 1k surley you need to get another quote somewhere else.
As Dave said its highway robbery
eagle56 is offline   Reply With Quote
Old 04-12-2009, 12:25 PM   #4 (permalink)
It was to replace the chain and sprocket was the quote. Could I get a step by step to adjust the chain maybe? Safely.
Old 04-12-2009, 10:58 PM   #5 (permalink)
Pebble Cruncher
Rockbiter's Avatar
Rockbiter is on a distinguished road
1. Put the bike on a lift
2. Loosen the rear axle nut. You *may* have to loosen the rear brake mount as well
3. adjust rear axle adjusters untill the chain is set properly (check tension at several locations)
4. ensure both sides are adjusted equally (measure from center of swingarm pivot point to center of axle, adjust adjusters untill both sides are exactly the same and chain is correct tension)
5. tighten rear axle nut. tighten rear brake mount (if previously loosened)
don't forget to clean and lube the chain while you are at it.
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote
Old 04-15-2009, 09:57 AM   #6 (permalink)
DILLIGAF
RattFXR is on a distinguished road
And after your done doing what rockbiter said,
1. Find dog poo
2. Place dog poo in bag
3. Go to Stealership, and open fron to door
4. Locate ass that told you 1000 dollars for I guess a 24kt gold chain
5. Lite bag on fire and hit him in the face with it
If no one voluntarily stomps fire out for him. Feel free to leave a boot mark on his head........
It's a machine, it's fixable. Unlike a woman.......
If it's "right", fix it......if it's "wrong", milk it as long as you can......
RattFXR is offline   Reply With Quote
Old 04-24-2009, 09:22 PM   #7 (permalink)
I'm told it might be a timing issue for the backfire. I would probably have to goto shop on that one?
Old 04-24-2009, 09:32 PM   #8 (permalink)
DILLIGAF
When you say backfire, do you mean out the pipe, or carb? Is in consistant, or only first start up to warm, or warm and on?
Backfire out of the pipes, generally is a rich condition. If it's out of the carb, a lean condition. But you need to be more specific about the "backfire". It is an ironhead, but as an 85 it may as well be an evo. Lots of help on here.
Old 05-24-2009, 10:38 PM   #9 (permalink)
dirtrace95 is on a distinguished road
Chain
You can go on ebay and buy a complete repair manual.
There pretty cheap and will save you a ton of $$$$$$
It could be the chain just needs adjusting. As for the back
fire issue... Strat with a new set of plugs. Gap them before
you put them in though..
I have the same bike, there very easy to work on.
dirtrace95 is offline   Reply With Quote
Old 05-24-2009, 10:44 PM   #10 (permalink)
back fire
Start with a new set of plugs, gap them right first. Another
thing is with oxy fuel it may to lean on the low end. You
might need open the fuel screw abit.
You can get a complete repair manual for these bikes on
ebay pretty cheap. You'll save alot of $$$ on fixing the small
things yourself. I have the same bike there very easy to work
on.
Old 06-04-2009, 08:39 AM   #11 (permalink)
skinhinahd's Avatar
skinhinahd is on a distinguished road
my 2006 XL1200L is doing almost the same thing, when coming to a stop it wants to turn off and will backfire out of the exhaust I have to give it gas or it will turn off, but will crank up again after stalling, any help?
skinhinahd is offline   Reply With Quote
