Wiesco Piston, Mentor, Ohio, manufactures a reverse dome unit that maintains OEM compression/weight.
FWIW, 8 lbs of cast iron(4 per hole) is removed when performing that work.
Most folks make mention of smoother running, once that upgrade is established.
Scott
