RRcycles.comDan Vance RacingFuel MotoMotorcycle.comCustom DynamicsProCharger.comCycleGear.comMotorcycle-CommunicationDiamond Bar Choppers
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Performance Forums > Sportster/Buell Engine Mods
R&R Cycles
Old 03-06-2009, 11:13 AM   #1 (permalink)
bathbeach is on a distinguished road
Bigbore Sportster
Can the STD sportster based case be bore to beyond 4" like 4.25 or 4.5" ???
thanks
bathbeach is offline   Reply With Quote
Old 03-06-2009, 11:23 AM   #2 (permalink)
Axtell is on a distinguished road
nope....3 13/16 is about the max...
Axtell is offline   Reply With Quote
Old 03-06-2009, 11:44 AM   #3 (permalink)
Axtell, according to their site, those aftermarket cases come in 4" bore stock. I could be wrong of course.
Old 03-06-2009, 12:32 PM   #4 (permalink)
KingofCubes's Avatar
Bore
Ron is referring to the stock bolt pattern XL cases, the raised deck spread bolt pattern cases that you're referring to are a different story. Get STD to fax me a bolt pattern drawing with specs and I'll tell you how big you can go.
King Of Cubes
515-266-6381
www.kingofcubes.com
Old 03-06-2009, 04:16 PM   #5 (permalink)
hightop's Avatar
hightop is on a distinguished road
Don't forget the deck height and spigot interference. I don't think these decks are as tall as the raised deck BT.
hightop is offline   Reply With Quote
Old 04-01-2009, 06:47 AM   #6 (permalink)
Iron Will
Hillside's Avatar
S&S has cases for that appilcation.
Old 04-02-2009, 01:25 AM   #7 (permalink)
prospecting everyone has
1fast2liter's Avatar
1fast2liter is on a distinguished road
why would it matter bore your stock cases and run the axtel 80 or 90" cylinders... any way you look at it your gonna spend like 5 grand on a good running quality build...
although i think you can get a 1550 kit or somthing thru s&s i think they have diferent cases and storker crank....
1fast2liter is offline   Reply With Quote
Old 04-02-2009, 06:10 AM   #8 (permalink)
Iron Will
Hillside's Avatar
You can build a mighty powerful XL, with the use of the OE bolt pattern, using 3 13/16" cylinders.
Several choices of strokes available.
Even at 88" (3 13/16" square) the power/weight ratio is so big that, not many will get around you.
Scott
Old 04-02-2009, 07:57 PM   #9 (permalink)
aint that the truth.. the anoligy i like is its like throwing a rocket on a bobsled.... you can get 100 hp out of 1200cc imagine at 1550cc..
Old 04-06-2009, 08:57 AM   #10 (permalink)
DILLIGAF
RattFXR is on a distinguished road
True, a very powerful bike with a square motor, but just think how powerful it WOULD be with a 4in or bigger bore, I think he wants to go fast....I agree, big bore, short stroke. Hello higher revs, more HP, Goodbye foreign stuff..... I for one am going to build it when I'm rich. Think 4in bore 3in stroke......... Piston speed low, revs high....could be fun in a Buell....
It's a machine, it's fixable. Unlike a woman.......
If it's "right", fix it......if it's "wrong", milk it as long as you can......
RattFXR is offline   Reply With Quote
Old 04-06-2009, 09:06 AM   #11 (permalink)
FXDRYDR is on a distinguished road
[quote=RattFXR;1573409]True, a very powerful bike with a square motor, but just think how powerful it WOULD be with a 4in or bigger bore, I think he wants to go fast....I agree, big bore, short stroke. Hello higher revs, more HP, Goodbye foreign stuff..... I for one am going to build it when I'm rich. Think 4in bore 3in stroke......... Piston speed low, revs high....could be fun in a Buell....QUOTE]
Yep - if you could keep the front end down!!!
FXDRYDR
2003 FXD
98" Small Bore
107HP/113TQ
FXDRYDR is offline   Reply With Quote
Old 04-06-2009, 12:03 PM   #12 (permalink)
Iron Will
Hillside's Avatar
We have done a couple 88" Axtell cylinder kits in Buells. All the clients say is, WOW!!!!!!!!!!!!!!
Even with OEM XL heads,(not Buell) Andrews V-6's, with a Supertrapp, they'll go 90-95 hp and 100-105 ft/lbs.
Scott
Old 04-06-2009, 12:41 PM   #13 (permalink)
DILLIGAF
Originally Posted by Hillsidecycle.com View Post
We have done a couple 88" Axtell cylinder kits in Buells. All the clients saw is, WOW!!!!!!!!!!!!!!
Scott
And that is a testiment to why sporty's are so much better!!!!!! 88 inches and 100 ft lbs of torque with stock heads!? I'm assuming they are ported but still. If the torque is higher then HP, then it's definitely still a somewhat conservative build. Heads setup and ported and bigger cams........ bye-bye.
Old 04-06-2009, 09:07 PM   #14 (permalink)
I have read that the S&S 100 (4x4) is a beast. With street version go 130+ hp and 120ft-lb. Any thoughts????
Old 04-07-2009, 06:58 AM   #15 (permalink)
Iron Will
Hillside's Avatar
I do not know the specs on that set-up.
Cams, heads etc.
Scott
