JardineProducts.comBub EnterprisesLeslie Kay'sCustom DynamicsMotorcycle-CommunicationMotorcycle.comSportbikeTrackGearBikeBanditProCharger.com
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Performance Forums > Sportster/Buell Engine Mods
Old 07-08-2007, 12:53 PM   #1 (permalink)
crpntr_iam is on a distinguished road
ironhead rejetting super e for drag pipes
i've got a '78 sportster, my question is to change to 1 3/4 drag pipes do i have to re-jet my carb? i have a s&s super e. if re-jetting is needed, what size jet do i use? any help will be appreciated.
crpntr_iam is offline   Reply With Quote
Old 07-08-2007, 02:20 PM   #2 (permalink)
dirtrace95 is on a distinguished road
jet
A 66 jet is pretty much what id run in that bike. The drag pipes will kill all your bottom end though. You might just want to think about some loader sort of slip on mufflers. The performance will be much better. Your not going to like the twist the throttle and wait for it thing that drag pipes give.
dirtrace95 is offline   Reply With Quote
Old 07-09-2007, 10:13 AM   #3 (permalink)
Iron Will
Hillside's Avatar
Drag Pipes
A 66 or 64 main with a 28 or 265 intermediate.
With most engines, a simple 1 1/2 long, 1/4" bolt, with 5/16 nuts, stacked up
(usually 3 will do),inside the pipe,
will control the reversion, and still give you the sound and look, and hardly effect peak hp numbers, but drives a pile of low end torque into the picture.
In some cases (and yours could be one of them) a 5/16 bolt with 3/8 nuts may be needed.
Works like a charm every time.
Old 05-01-2009, 04:51 PM   #4 (permalink)
drag pipes
I used some 1/4in thumb screws and turned them side ways,
there even adjustable. While on the dyno I kept turning them
alittle more till the peak hp just started to drop, locked them
there and the bottom end was good too.
