Originally Posted by bigguns55
Hi - Just got a new rear tire put on my 05 fatboy. I bought a tire at a dealer and had it changed at a tire shop in town.When I took it for a test ride I had no rear brakes! As it turns out they bent the brake rotor when changeing the tire.Is there anything else that should be checked to make sure they did not screw anything else up? any info would be great.
Guess that wasn't the right place to save a few bucks...Bummer.
Plus you can get the same tires at a better price in aftermarket...
Before ya remove the back wheel I would get back of bike up off the ground & using an "indicator" slowly turn the wheel to check the rim for possible run-out damage as well..
Just FYI, a good rim will still have a slight bit of run-out....
I would be very carefully inspecting everything..
Hope they are gonna pay for yer damage(s)..
Look at yer caliper in around the pads as well..
Hope you get sorted out..
