» Buyers Guides |
05-28-2007, 05:38 PM
#631 (permalink)
Originally Posted by Lowrider05
Creamin,
Are those Boss Bags #36 fairly roomy? That is the size that I am considering for my new fatboy. I also looked at the #42, but was afraid they may be a little too big. Thanks for you help.
Chris
I would like to know how you got those bags on without relocating your turn signals??
And are the bags quick release? Been trying to figure out what to do to my 06 fatboy on long trips.. thanks
Rick
06-02-2007, 11:53 AM
#632 (permalink)
Creamin,
Chris
Rick
The 36ers are a very nice size, I can fit a half helmet in them with no problem, and they have quick detach hardware with no turn sig relocation. however, the 42's dont have detachable hardware and I'm not sure about the turn sig's with them, also you will have to have some low exaust with them as well, just give them a call and they will give you the low down on all the combinations for your bike.
CREAMN 1
______________________________________
2006 FLSTFSE² Screamin’ Eagle® Fat Boy®
SE Race Tuner
SE 8mm Spark Plug Wires
SE Stage I Air Cleaner w/ K&N Filter
V&H Big Shots Staggered
Lyndall racing brakes
Kuryakyn Mark IV Cruise Arms
Boss #36S1 saddlebags
Corbin gunfighter w/wildfire Stitch, red flames & backrest
________________________________________
HOME PAGE
06-04-2007, 05:40 PM
#633 (permalink)
SlowHand
Hey!
Anyone have any ideas about installing an oil pressure gauge and maybe a tach on a Fatboy? I have an 04, and I don't see much info on this setup!
I've found mini tachs and speedo combos, but I have a speedo, I want to know my oil pressure at all times! Just changed over to Amsoil and picked up a couple of noises that are bothering me! Thanx Pappie
06-04-2007, 07:53 PM
#634 (permalink)
ovanay elinquentday
Originally Posted by Pappie
Hey!
Carrie and I both have the oil pressure gauge mounted in the typical location - right side, mounted to the rear rocker box bolts.
http://www.v-twinforum.com/forums/sh...&postcount=626
I went for the speedo/tach combo.
03 Fat Boy
Slammed rear
More Chrome
John Bernard Books
43+ HP / 43+ Ft-lbs
06-04-2007, 09:32 PM
#635 (permalink)
Wicked!
Originally Posted by GPO03FatBoy
You got a upclose of that combo? I've been wanting to add the tach also, but I don't want in on the handlebars. Thanks for the recognitions, GPO03Fatboy!
Here's an upclose of the oil pressure gauge...
06-04-2007, 10:19 PM
#636 (permalink)
ovanay elinquentday
What can I say? I like your lines!
03 Fat Boy
Slammed rear
More Chrome
John Bernard Books
43+ HP / 43+ Ft-lbs
06-04-2007, 10:53 PM
#637 (permalink)
Rear lowering kit for 05' Fatboy
Has anyone lowered the rear of their Fatboy? I have an o5' with an extended warranty that runs through 09'. Would it impact my waranty if I bought the lowering kit through the dealership? And, should I be concerned about clearance, both with the fenders and road? Am I asking the right questions? Thanks in advance...
.. david lee
06-04-2007, 11:59 PM
#638 (permalink)
Incredible
Yes you can lower it and don't go more than 2" and you are fine. It will ride different at 2 full inches lowered though. Just so you know.
BTW. Dump that extended warranty and pocket the cash. The only person making money on that warranty is the company you bought the policy from.
06-05-2007, 12:05 AM
#639 (permalink)
Incredible
Hey!
I have one of the Ness Oil Pressure gauges also.
This is the tac I have on my bike. It is the DHT-1000. Not in the way and very useful.
06-05-2007, 12:33 PM
#640 (permalink)
When you say it will ride different...how would it ride different? Stability-wise, or how? Also, the kits I see from HD dealership only take it down 1". Since I do have the warranty...any gotchas there?
Thanks...
.. david lee
06-07-2007, 09:09 AM
#641 (permalink)
Incredible
When you lower something (unless you use different shocks that have tighter coiled springs) you are just lossing shock travel. 2" lowered bikes ride very stiff compared to a standard height bike. Personally I would not use a 1" lowered HD shock. The progressive shocks would be a much better choice for a 1" lowering kit. Also I would lower the front as well.
06-08-2007, 03:46 AM
#642 (permalink)
Looks like there's not enough FatBoys out there...
OK, I'll try to post a picture of my FLSTFSE a 2005 Screaming Eagle FatBoy with some mods to keep it interesting.
06-08-2007, 05:36 AM
#643 (permalink)
Wicked!
Very nice!!!
06-08-2007, 11:57 AM
#644 (permalink)
ovanay elinquentday
Thanks...
.. david lee
Lowering seems to be a matter of personal preference. I ran the Progressive lowering springs about 2" down on the rear for a long time. Just had to keep the preload up so it didn't bottom out on bumps, and had to be careful when going over speed bumps. The biggest negatives are that you may wear the surface of the back of your belt on the starter jackshaft, and your cornering angles will be significantly reduced. (You'll move from scraping your boards to scraping the frame in the middle of the bike.) Ride becomes stiffer too.
I have the Progressive Airtail system now and alternately run it from a little higher than stock for cornering, to dropped down almost to the stops for looks. Again, cornering safety and belt wear are the biggest problems when lowered.
Also, especially with my bike lowered down on the stops in the rear, I'm glad I did not lower the front. Drop the front and your lean angles are gone. Plus, for me, I like the look of the lowered rear with the stock height front.
Just sayin'...
03 Fat Boy
Slammed rear
More Chrome
John Bernard Books
43+ HP / 43+ Ft-lbs
06-09-2007, 05:43 PM
#645 (permalink)
Heres a pic of my '06
Hi all! I just signed on and saying hello from New Hampshire! Heres a pic of my 2006 FI:
