#1
Aug 14, 2007
Helping a friend put new tires on his Sporty. Need ot know the torque specs for both front and rear wheels on a 97 883.
#2
Sep 8, 2007
I want to tighten up the belt on my 05 Custom but I'm not sure of the torque specs for the axel, I plan on buying the manual but haven't yet so any help would be appreciated. On my Ultra it's 105lbs but I've heard that some bikes are 65, just want to be sure so I don't cause bearing damage...TIA
#3
Sep 8, 2007
For an the XL {my RK & Dyna also} its 50-55 for the front, 60-65 for the rear axle nut.
Where did U get 105lbs from?
#4
Sep 8, 2007
On my Ultra it's 95-105 lbs on the rear, per the service manual
#5
Sep 9, 2007
Rear axle torque spec's were changed when HD went to the larger rear axle and axle cams to adjust the rear belt.
If I remember correctly (going all the way back to Evo's at least), the rear axle is 60-65 lbs. Front is 50 lbs.
#6
May 9, 2009
Can anyone tell me what the torque specs are for the two axle clamp nuts on the front right side of a 2005 road king. Thanks
