Motorcycle.com Classifieds!
AdvanstarMotorcycleShowsMotorcycle-CommunicationJardineProducts.comBikeBanditMBO EnterprisesProCharger.comRRcycles.comAmerican Side Road CycleCycleGear.comFuel Moto
Dan Vance Racing
Old 08-30-2009, 03:06 PM   #1 (permalink)
crzrlou is on a distinguished road
Gel Coat Question
I have a trike body on order and it will be coming with just a gel coat. Can anyone tell me what I need to do to it before I paint and clear coat it??
crzrlou is offline   Reply With Quote
Old 08-30-2009, 03:09 PM   #2 (permalink)
I HATE 'bing'...
TriLs's Avatar
TriLs is on a distinguished road
PAT!!! You out there???
Where's Pat???
____________________________________________
"It ain't what you don't know that gets you into trouble,
it's what you know for sure that just ain't so..."
Mark Twain
Live well...Love faithfully...Laugh often.
Vivid Black '09 TriGlide, V&H Dresser slipons, SE Stage 1 A/C, fairing-mounted oil temp, small bits o' glitz, and rear-hatch H-D rain closet (next project).
TriLs is offline   Reply With Quote
Old 08-30-2009, 03:15 PM   #3 (permalink)
SVD999 is on a distinguished road
depending on the qaulity of the piece it can be as little as sanding with anywhere from 220 to 400 gritt and priming. if its wavy or has pinholes or other nasty looking crap it can be corrected with a good poly.
SVD999 is offline   Reply With Quote
Old 08-30-2009, 07:51 PM   #4 (permalink)
mooooving out!
route66paul's Avatar
Many places can put the color right into the gel coats, this is the best way, paint has a hard time sticking as well(or so my indy tells me).
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 08-30-2009, 08:31 PM   #5 (permalink)
Custom Painter
kustom_flames's Avatar
Where's Pat???
Ooooops, must have been snoooooozin...
As stated, a good sanding beforehand would probably be sufficient. You could also apply some 'bulldog' which is an adhesion promoter. I use it b4 I lay down primer on ABS parts, but is used to promote adhesion on other surfaces as well. I would use a high build primer on it, shoot 3-4 coats. Then it wouldn't hurt to lay down a guide coat (mist on some black paint) and then when you wetsand you will see if there are any 'low' spots...
Old 08-30-2009, 09:31 PM   #6 (permalink)
Wallet Weary
Traakon's Avatar
Traakon is on a distinguished road
Just be cautious not to sand away the gel coat, it is what keeps the fiberglass stable. If you sand it through completely the fiberglass can "move" and cause the paint/top coat to crack or wrinkle.
'00 Custom Deuce, '05 Custom Fatboy, '03 Roag King -current custom project-
-A man and his money soon (and often) parted.-
Traakon is offline   Reply With Quote
