ProCharger.comCycleGear.comDiamond Bar ChoppersPro Pad
American Side Road Cycle
Motorcycle.comFuel MotoBikeBandit
American Side Road Cycles
Old 07-23-2009, 08:01 PM   #1 (permalink)
Booggerbe's Avatar
Booggerbe is on a distinguished road
one piece top clamp
Ok Forum have a question on a part number from harley. I am going to put the wild 1s 575 on my 06 street glide and have been told that i need the one piece top clamp for the bars to keep them from breaking. Is there a stock harley part for this or where do i need to get this one piece from. If it is a harley part does anyone have the part number or give me some input on this top clamp for the bars. Thanks Booggerbe
2006 SG 98" Hyperformanc/R&R/Axtell motor. 11.3 comp, remodified R&R billet heads, R&R cam plate, R&R 615/585 cams and gear drive. 1.675 Roller rockers, modified 07 oil pump, Reworked Hyperformance crankshaft, Axtell cylinders and pistons custom cnc by HyPerformance, Bob Wood Rebel carb, wood a/c, DTTT ign,Baker od 6 speed, Arnott air ride, pro-clutch, 3:37 gearing, 123.46hp / 119.01tq.
Booggerbe is offline   Reply With Quote
Old 07-23-2009, 09:33 PM   #2 (permalink)
repeat offender
Flyin Brian's Avatar
Flyin Brian is on a distinguished road
Hey Boogerbee, I installed cyclesmith apes on my SG and I ordered a one piece clamp from HD, but it didn't fit out of the box. It was too thick, so the stereo wouldn't sit down where it should. I ended up grinding a lot of material off it with a makita grinder, and finally got it to work. Anyhow, after I finished the install, someone told me there is a top clamp made by harley that fits without modification. They said it was the one that has "Ride to live, live to ride" slogan on it. I don't know any more than that, I'm thinking maybe that clamp is made of steel, and therefore thinner, which would make sense that it would fit under the stereo. The plain chrome one I used was aluminum, hence the thickness being too tall.
Good luck, hopefully someone will have a better answer.
2006 FLHXI Street Glide
GMR 98" R&R CAST HEADS
R&R 615/585 cams - S&S Gear Drive
roller rockers
HP INC 55mmTB SERT
Choose Revolution Performance and prepare to be piston slapped!
This message has been sent to you using recycled electrons exclusively. Please do not discard them after use, send them along and help conserve these irreplaceable sub-atomic resources for future generations.
Flyin Brian is offline   Reply With Quote
Old 07-23-2009, 10:16 PM   #3 (permalink)
Booggerbe's Avatar
Thanks Brian, Ill check it out at Hd and see if the bolt holes will be the same. Thanks Booggerbe
Old 07-24-2009, 12:14 AM   #4 (permalink)
Premium octane member
TXCHOP's Avatar
Ron, 55918-08 is the clamp you need. Bout 40 bucks if i remember right. Fits great in my fairing. Done 3 with that clamp and all have been fine, even with the apes on mine.
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
Old 07-24-2009, 10:11 AM   #5 (permalink)
Booggerbe's Avatar
Thanks Tx, That is the imfo i was looking for. Some throttle cables and i am off to work. Thanks Ron
