AdvanstarMotorcycleShowsMotorcycle.com Classifieds!RRcycles.comJardineProducts.comDan Vance Racing
CycleGear.comSportbikeTrackGearCustom DynamicsPro PadMBO Enterprises
Old 06-23-2009, 11:30 PM   #1 (permalink)
Scoop4530 is on a distinguished road
Question for Pat
I seen on your home page that you have shot HOK kameleon kolors and PPG harlequin colors, do you like one over the other? I'm still trying to pick colors and a design for my paint job. The only dealer in my town is PPG. They tell me that ppg primers and sealers will work find under HOK products. Do you agree with that?I think the cost will be higher with HOK, but if the colors stand out better it's worth the added cost.
Chuck
Scoop4530 is offline   Reply With Quote
Old 06-24-2009, 08:28 AM   #2 (permalink)
Custom Painter
kustom_flames's Avatar
Hey Chuck! Actually PPG is more than HOK in alot of places. I recommend the PPG shopline primer - JP202. It lays down flatter than any other primer I have ever used, and unless you ride your bike in the snow, you do not need an epoxy primer. The PPG harlequin blew the doors off the HOK I used. Similar, but it did seem to change a few more shades than the HOK one I used. BUT, that goes for about $50/ounce and I think you have to buy the whole thing at 6oz, unless your PPG supplier will sell you some of theirs... I also just switched out from HOK UC35 clear to the PPG DBC8152 Glamour Clearcoat. The PPG clears give way more depth in less coats than the HOK. I had a tank side by side, one that had 8 coats of UC35 on it and the other with 4 coats of the PPG - PPG looked deeper. The PPG clear will also run you twice as much...
If you are going to use PPG and HOK, use the SAME reducer throughout - whether it be HOK or PPG, and you should be fine. Be careful with the HOK BC25 black - that one seemed to be finicky to me, though the PPG DBC9700 will cost you about $30 more. Do not buy the PPG shop line black - it is not a deep enough black!
The PPG clear I mentioned does not come in quarts, so you would have to buy a gallon setup, which will run you more than $400! You can ask them about the 2042, which you can buy in quarts....
I really like the PPG line, and IMO it is worth the extra money. PPG supplies the paints for HD. Hope all that helps...
Pat
Old 06-24-2009, 11:22 PM   #3 (permalink)
Thanks Pat, that is some good info. Have you shot or seen HOK kameleon kolors or PPG harlequin colors used with the marblizer ?
Chuck
Old 06-25-2009, 10:14 AM   #4 (permalink)
Custom Painter
NOt really, but what I did do recently, that was very cool, was shoot lectra finish (crystallizer) over the PPG harlequin. Check this out for the effect: http://www.kustomflames.com/lectra_guitar.html
