Hey Chuck! Well first off I love Iwata, so you got the right stuff to do the job! Before you paint anything, you may want to strip that rattle can paint off as it very well may cause a reaction with the paint you would be applying over...
If you are wanting kameleon as your base coat, you will need at least 1qt. The kameleons are nearly $300 for a pint, so you very well may be spending more than $1k just for materials - primer, clear, reducers, etc...
It really is about the same as spraying basecoat, so you will probably do just fine! I'm happy to answer any questions you may have.
Pat
" Life's too Short for Bad Paint"
