Glass or ABS? If glass, you can use 'kitty hair' to patch - has actual strands in it and works great. Then I usually do a skim coat of filler over to smooth. If ABS, they do make a special filler for that application, but I have never used it to repair drilled out holes before.
Be prepared as it will take 3-4x the materials and time as that softail did...
Good luck,
Pat
" Life's too Short for Bad Paint"
