BikeBanditSportbikeTrackGearPro PadJekillandHyde.euFuel MotoMBO EnterprisesProCharger.comMotorcycle.comCycleGear.comAmerican Side Road CycleDiamond Bar Choppers
Old 04-05-2009, 07:37 PM   #1 (permalink)
Nickrc3 is on a distinguished road
Effective product of stripping H/D paint?
I recently purchased a used set of fenders and gas tank from a 2000' Fatboy so I may apply a custom paint then fit to my 04' Fatboy.
My questrion regards stripping the original paint from the sheetmetal. I'm using Home Depot's best paint remover, a Kleen-Strip product ,and it's barely doing anything. Even beyond the clear coat, it's taking 6-8 applications of this product and yet, still not completely stripped. Even tried heat from a propane touch!
Are the boat/marine paint stripping products more effective? Really donot wish to sand blast. I'm actually wondering if I should simply sand the existing finish to provide the tooth, then seal, prime, basecoat and clear. Why completely strip?
Please advise.
Thanks guys.
NICK
Nickrc3 is offline   Reply With Quote
Old 04-05-2009, 07:41 PM   #2 (permalink)
Faast Ed is an unknown quantity at this point
I hope you get a good responce, cuz I been down your street! LOL
Best of the ace hardware/ home depot stuff, took me endless hours with steel wool and plastic gloves. No easy way, that I could find. The aftermarket paint that was on top of the OEM paint about fell off by itself. But the OEM paint I found to be bullet proof.
Do you have a buddy with a sand blaster?
While I see the motivation to stop short, don't do it. If you want perfection, keep going til you're done. You will not regret it.
Get cha a nice comfy chair in the garage, a few beers, perhaps a little TV. You'll get there eventually.
Faast Ed is offline   Reply With Quote
Old 04-06-2009, 10:40 AM   #3 (permalink)
Custom Painter
kustom_flames's Avatar
Yeah, don't strip it all off! Knock off the decals to bare metal and feather the edges in. HD uses some of the best primers, so you already have a very suitable substrate to work with. Going over one paint job will not be a problem as long as it is factory.
Chemical strippers will make a very gooey mess - I prefer a good high speed DA with 80 grit anyday....
Old 04-06-2009, 11:28 AM   #4 (permalink)
extant
OZNOG's Avatar
OZNOG is on a distinguished road
But if you need to strip paint-
Here's the stuff, BUT BE CAREFUL and follow precautions!
http://www.wmbarr.com/product.aspx?catid=33&prodid=136
Aircraft Remover by Klean Strip
This will make most paints AND body fillers melt like a Halloween
nightmare. READ: Do not get on anything you value, like skin,eyes,plastics etc.
HD paint, especially on the frames sure is tough as nails, but if you already have "a mess" from other strippers; try a couple round of this stuff. Then clean/feather/prime.
Use outdoors, with gloves, and eye protection. Good Luck!
95" 2006 Street Bob
Hillside modified 06 heads
D&D FC / standard
Wood 9b @11.6
HPI 51
...please stay tuned.
OZNOG is offline   Reply With Quote
Old 04-06-2009, 11:59 AM   #5 (permalink)
uid100's Avatar
uid100 is on a distinguished road
Originally Posted by Nickrc3 View Post
My questrion regards stripping the original paint from the sheetmetal. .....
Asphalt.
But it's not advised and hard to control.
uid100 is offline   Reply With Quote
Old 04-06-2009, 01:26 PM   #6 (permalink)
extant
OZNOG's Avatar
Originally Posted by uid100 View Post
Asphalt.
Neither is sandblasting or a PROPANE TORCH!
-and with my apologies to Springer;
"what do I know, I ride a flat black bob"
95" 2006 Street Bob
D&D FC / standard
Wood 9b @11.6
HPI 51
Old 04-06-2009, 03:07 PM   #7 (permalink)
oKustom Flames,
the existing clearcoats are applied so thick decals and tape pinstriping are below the top surface. So, simply provide some tooth using 80-120 grit and reprime with a epoxy (catalyst) product? Will a sealing product be necessary before he primer? I have used both PPG and Matrix paints in the past with spraying military schemes on large-scale radio-controlled model airplanes.
Yeah, not stripping the tins is definitely in my best interest. Any other tips you may provide would be greatly appreciated.
NICK
Old 04-06-2009, 05:20 PM   #8 (permalink)
Custom Painter
Yeah knock down the decals with 80 or 120. You'll want to feather those edges down with 220 and 320 grits. You do not need a sealer. PPG shopline primer JP-202 is what I use and it lays down flatter than any other primer I've sprayed.
Make sure you do use a high build primer too. You can use an etching primer first on the bare metal part, but not necessary if your other primer is suitable for bare metal.
