Ok first, you can use a plastic adhesion promoter, such as bulldog. Then a flexible primer of any color can be used over that.
I think with a red metallic you will be ok no matter what is underneath. Base colors come more into play when using pearls. For instance a light pearl such as white, yellow, orange, will probably be a shade different if going over say black and white. In fact they recommend a white base....
What you are going over now, is it ABS in its raw state or already painted? If already painted, chances are you can scuff that clear, prime, and shoot your red metallic, and you do not need a plastic primer....
" Life's too Short for Bad Paint"
