Anyone have the 2008 Paint Codes? : V-Twin Forum: Harley Davidson Forums
Old 02-09-2009, 11:53 PM   #1 (permalink)
sg4145 is on a distinguished road
specifically...the Dark Blue Pearl...inquiring minds want to know...
sg4145 is offline   Reply With Quote
Old 02-10-2009, 04:43 PM   #2 (permalink)
Axe Man
BVBOB's Avatar
I have been trying to get a complete list together for the 08's, just havent had time, do you know the exact name Harley used for the paint. I am sure with that I can get you the proper ppg code.
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
Old 02-11-2009, 02:37 AM   #3 (permalink)
the color I'm looking for is called "Dark Blue Pearl"
Old 02-11-2009, 03:22 AM   #4 (permalink)
NJ RIFF RAFF's Avatar
NJ RIFF RAFF is on a distinguished road
Check page 729 of the '09 catalog. They have colors listed for Dark Blue Pearl. Hope that helps.
NJRR
"If I choose not to decide, I still have made a choice!"[/B]
08 FXDC
V&H Big Radius
V&H Fuel Pak
Stage1 A/C
Mini Apes
Sundowner Seat
Progressive 412 Shocks
Mini Tach
BLING-BLING-BLING
NJ RIFF RAFF is offline   Reply With Quote
Old 02-11-2009, 06:42 AM   #5 (permalink)
timbo141's Avatar
timbo141 is on a distinguished road
DARK BLUE PEARL DENIM 2006 (Date first year used)
[Harley code: 66328, 8L56, 6308B]
[PPG Code: 922943]
Must apply a flat clear. PPG Soft-Touch Designer Clear VC5225 Works best.
timbo141 is offline   Reply With Quote
Old 02-12-2009, 05:25 PM   #6 (permalink)
nope...that's not the right one...it's not the denim or flat color...if you go back to the Harley website & look under 2008 motorcycles...one of the available colors on the 08 Street Glide is "Dark Blue Pearl"...that is the one I am still looking for...
Old 02-12-2009, 07:09 PM   #7 (permalink)
timbo141's Avatar
The name threw me off as the Denum was the only one PPG has as "Dark Blue Pearl"
There is a "Dark Blue" they have listed and there is a CRYSTAL RED PEARL in the formula.
There is a "Prime" and a "Greener than Prime" under "Special" colors.
DARK BLUE 2008 Body
Harley code: 8L56
PPG Code: 917828
I see that under both "Names" they have Harley Code:8L56 After looking at both formulas they are identical. Just different clears on top, one gloss and one flat.
Hope this helps!
Old 02-13-2009, 03:10 AM   #8 (permalink)
thanks Tim...I'll give that a try...
Old 02-15-2009, 12:23 AM   #9 (permalink)
Thanx Timbo...that did the trick...I appreciate the info...
Old 02-20-2009, 02:36 PM   #10 (permalink)
SoCalitems.com's Avatar
SoCalitems.com is on a distinguished road
Can anyone help...I also need a couple codes.
Crimsen sunglow red.....and .....Chopper Blue....
SoCalitems.com is offline   Reply With Quote
Old 03-13-2009, 01:35 PM   #11 (permalink)
harleypete is on a distinguished road
hello, does anyone have the paint code for 07 ppg pewter denim, thanks
harleypete is offline   Reply With Quote
Old 03-13-2009, 04:16 PM   #12 (permalink)
kustom_flames's Avatar
kustom_flames will become famous soon enough
I have it at the shop...can get it on Sunday for you...
PPG should be able to tell you though and then you shoot their flex n flat clear over it...
Old 03-13-2009, 05:57 PM   #13 (permalink)
thanks bud, i really need it
Old 03-13-2009, 08:26 PM   #14 (permalink)
scottmizer is on a distinguished road
2008 paint codes and more
here are your codes
(don't ask where I got them)
File Type: pdf PM_custom_vehicle_color_chart_2000.pdf (449.7 KB, 114 views)
scottmizer is offline   Reply With Quote
Old 03-15-2009, 05:05 PM   #15 (permalink)
Pewter Pearl Denim is
PPG 922952
OEM 6308B,7A54
What it says on the can...
