Friedenfels, I've got the Street Slammers on a 2006 FXSTB.
For me, the thing is this; there isn't one optimal riding position. A solid riding position could be with the knees and hips bent at 90 degrees, with a vertical spine, or it could be the opposite with knees and hips bent acutely, and spine somewhat rounded.
I'm looking into the Corbin Solo, not the Hollywood version, mostly because I'm wide, even in good shape I have a 33-34inch waist, so the seat should support the breadth through my hips and provide a wider contact patch; so, I'll be supported through more than the small point of support given by the Brawler seat. I'm also looking into bars that have the same height, and width, but have more pull-back. I'll start with the seat though because if the seat drops my seat height significantly then I might not need to bring the bars back for the reasons I've given above.
Good Luck and let me know what direction you end up going.
