Wide Glide Seat Removal and Replacement
Hello All, Finally got my HD 2002 Wide Glide and wanted to consult with more experienced folks before i switch out my OEM seat. I am assuming that all i have to do is remove the screw on the rear fender and slide the seat back to remove correct? Then i simply slide the new seat (LaPera sillhoutte) onto the bracket and screw into place on the fender correct? (I know, i'm an idiot but better to be safe than sorry!)
Also, the stock backrest should also be easily removed by removing the screws that hold it in place and then replacing the screws correct? (I'm obviously not just an idiot but an insecure one to boot!). Thanks for any assistance.
