AdvanstarMotorcycleShows
Motorcycle-CommunicationBub Enterprises
Custom DynamicsJardineProducts.comMotorcycle.comMBO EnterprisesCycleGear.comLeslie Kay's
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Forum Sponsors Section > Rosa's Cycle
Old 10-08-2008, 06:49 PM   #1 (permalink)
Site Sponsor
rosascycle's Avatar
rosascycle is on a distinguished road
2009 SERG & Rinehart Slipon's
Just Dyno tuned a 2009 S/E 110cuin CVO Roadglide with Rinehart slip on mufflers and supertuner. 91HP & 116.7TQ The only bad part it isn't mine to enjoy. Just might be nicest riding touring model to date
PH: 631-424-4955
Huntington, New York 11743
http://www.rosascycle.com
rosascycle is offline   Reply With Quote
Old 10-09-2008, 04:43 PM   #2 (permalink)
sblair is on a distinguished road
Thanks for that great info. Should have told the customer that you could have gotten a couple more horsies by using a SE Heavy Breather and triple platinum plugs!
sblair is offline   Reply With Quote
Old 10-09-2008, 04:58 PM   #3 (permalink)
FLSTFI Dave
Nice....
I cant wait till true duals come out so the cat in the head pipe is gone, with the SE heavy breather too. Should have real nice numbers with out getting into the engine.
09 CVO Road Glide, Silver / Titanium,
09 FLSTC Heritage Teal and Antique White, wifes ride
06 Chevy crew cab 3500 duramax
80 Vette, ZZ4 small block, 355HP and 405 torque
FLSTFI Dave is offline   Reply With Quote
Old 10-10-2008, 09:59 AM   #4 (permalink)
Uhhh, you lose HP going to true duals. The 2 into 1 back to 2 works really well. Spend less and get the same pipe for the 96" (without the cat!). Flow is pretty even through both sides! Or... rumor has it that you could spend about $30 for a 1.6 core drill bit and drill out the cat!
Old 10-12-2008, 12:53 PM   #5 (permalink)
FLSTFI Dave
While that is true, A bagger just does not look right with a 2 into 1 and especially not the SERG with the cut outs for both pipes.
Old 10-12-2008, 04:49 PM   #6 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
WOW nice torque curve for touring. What else was done? Air cleaner?
Old 10-13-2008, 09:41 AM   #7 (permalink)
Site Sponsor
rosascycle's Avatar
Slip on Rinehart mufflers And racetuner NO A/C kit Thats it
PH: 631-424-4955
Old 10-13-2008, 04:32 PM   #8 (permalink)
FLSTFI Dave;
The point I was trying to make was why install true duals on the 09's when you already have a 2 into 1 stock. If its a 110 or Ca 96 then it has the cat which could fall out or... you could spend $500 and get the non-Ca 96 headers without the cat.
Old 10-14-2008, 10:13 AM   #9 (permalink)
FLSTFI Dave
FLSTFI Dave;
I will watch for some take offs from a 09 96" at the dealer.
What I would really like is for BUB or V&H to make a two into one into two header.
Old 10-16-2008, 04:41 PM   #10 (permalink)
Hmmm, there ya go! But why waste the money? Would the BuB or V&H be that much better? Let someone else spend the money and then take their 96 headers....
Old 10-17-2008, 08:31 AM   #11 (permalink)
FLSTFI Dave
Notice I did say I would watch for 09 96" take off.
I think they may be better. I know the Thunder header and the Pro pipe give the most torque. Torque is what I like.
Old 10-17-2008, 04:06 PM   #12 (permalink)
Yea, the stage 1 with a tune on the Dyno and Fullsac baffles at $120/pair is getting 115ftlbs torque at the wheel. I think that will work without splitting the case!!!! Always heard the ThunderHeader was about the best for power/torque. tough decision.
Old 12-18-2008, 07:33 PM   #13 (permalink)
Do the math, first !!
thedriver's Avatar
thedriver is on a distinguished road
Se 255 ???
Can you tell me the actual CR or CCP of that 110, also is that the SE 255 that comes with. i'm doing a 103 freshin up 0n my 07 Ultra , changing to SE 255 @ 9.5:1 for touring. need all power 2K - 3.5K . THAT LOOKS GREAT FOR TOURING !! Thanks
[ 07 Ultra 103 CI - SE\AC - cast flat tops - BigBoyz heads - 9.5 CR - .034 sqiush - SE255 cams - SE cam plate - Baisley spring - SE roller rockers - SERT - 30 tooth trans - IDS - Fatcat QB -
thedriver is offline   Reply With Quote
Old 12-19-2008, 07:39 AM   #14 (permalink)
Site Sponsor
rosascycle's Avatar
Bike we tuned was showroom stock 255 cams come standard in CVO 110cuin 2009 models.We never checked CCP you would have to disable the compression releases to check CCP.HD claims the 110cuin is 10 to 1 CR but I don't know that for a fact
PH: 631-424-4955
Old 12-19-2008, 03:52 PM   #15 (permalink)
thedriver's Avatar
Have you done any 103s & SE255s with the same TQ. curve but lower #s. it seems hard to beat for touring. i would think the FatCat would be of some help to. thanks
