SportbikeTrackGearOriginal Bike SpiritsCustom DynamicsMotorcycle.com
BikeBandit
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Motorcycle Related Groups and Forums > Riders Gear: Clothing & Accessories
Bike Bandit
Old 11-29-2006, 12:42 AM   #1 (permalink)
SSC
SSC
Cold weather boots
I need some suggestions for cool to cold weather boots. I have read the other threads regarding boots, but they don't seem to talk to much about cold weather boots. Do you cold weather riders use insulated boots or just heavy socks with regular boots?
Let me say I am from So. Cal and this isn't a common problem. Trying to even find insulated boots to try on is a challenge. For me when it gets below 62 my feet start to feel the cold. I know, I'm a sissy, but I would like some thoughts on what to wear in cold weather. I usually go with heavy wool socks, but have thought I should get some insulated riding boots.
All my hunting boots seem too big and bulky. Thanks for any info.
Regards, SSC
SSC is offline   Reply With Quote
Old 11-29-2006, 09:03 AM   #2 (permalink)
geoffreyt is on a distinguished road
I can see your So. Cal. problem. Thats a tough one. I would say that a pair of leather boots, and wool socks should do the job. I ride down to 40 or 45 degrees with simply over the ankle leather boots and wool socks. If you want boots, get some. THere are so many to choose from its enough to spin your head. West Coast Boots in Seattle will make you a pair with your choice of linning. Nice stuff.
geoffreyt is offline   Reply With Quote
Old 11-29-2006, 12:34 PM   #3 (permalink)
This space is blank
DCRANER's Avatar
DCRANER is on a distinguished road
I am in Jersey, gets real cold here. But, I just have a good pair of black Red Wing insulated lace up work boots.
Comfortable, warm, water proof, and will probably last 10 years and then you just have them resoled. They have versions for different levels of cold, so they probably have something to meet your Calif. needs.
07 FLHRS Cobalt Blue:Stage1 Download, Andrews 26H Cams, V&H FuelPak, Cobra Slip-Ons, K&N 3909, HD Oil Cooler, WILD1 Chubbys, Turn sig. relocate, Braided cables, Metzler 880's, Floating Rotors, IDS.
DCRANER is offline   Reply With Quote
Old 11-29-2006, 12:37 PM   #4 (permalink)
Turgid member
rgraham's Avatar
rgraham is on a distinguished road
These boots rock. They are lined and insulated. My feet never get cold when I wear these, and it gets a bit colder up here than in SoCal. They don't really need much break in either.
http://www.chippewaboots.com/boots/d...e=118&id=27862
rgraham is offline   Reply With Quote
Old 11-29-2006, 03:21 PM   #5 (permalink)
Acquisitions
dynageno's Avatar
dynageno is on a distinguished road
I been wearing Bates boots from Sears about 70 to 90 dollars. They work pretty well and are light weight!
Back in Black
dynageno is offline   Reply With Quote
Old 11-29-2006, 03:59 PM   #6 (permalink)
davukmer's Avatar
davukmer is on a distinguished road
I'm of the theory that one doen't need insulated boots.
The secret is Wool socks worn with a light sock liner, such as Capilene from Patagonia.
Wool will insulate even when wet.
The sock liners remove the itchy-sratchy wool from against yer skin. The sock liners, made of Caplilene, will wick moisture AWAY from your skin.
Feet= dry and warm...and NOT itchy.
Wool socks= wet from sweat...still doin' their job.
There are several proprietary blends that will wick moisture....Capilene is cited only as an example.
'01 FatBoy Stage 1
davukmer is offline   Reply With Quote
Old 11-29-2006, 04:21 PM   #7 (permalink)
Longtime Asphalt Cowboy
Texan's Avatar
Texan is on a distinguished road
Despite what some people think it gets cold in the Panhandle of Texas (28 outside right now). What we usually do is put on a pair of light-weight nylon (dress socks) and then wool socks over them. Then a good pair of insulated boots. Kinda like what davukmer was describing.
I have to admit that I have a pair of Gerbring heated socks that work great. Have a buddy that wears a product from PolarWrap called ToastyFeet that he swears work great. ??? I've never tried 'em.
o~\o
Texan is offline   Reply With Quote
Old 11-29-2006, 04:45 PM   #8 (permalink)
Keep the rubber side down
nixdad's Avatar
nixdad is on a distinguished road
If you don't mind lace-up boots, I used my insulated Danner boots to ride up in Washington State when I lived there. I rode year round and my feet stayed dry and warm. When I wore my slip-on boots I just wore a pair of ski socks and that made a lot of difference.
04 E-Glide Standard
95" Big Bore
SE A/C
V&H Pro Pipe HS
nixdad is offline   Reply With Quote
Old 11-29-2006, 07:06 PM   #9 (permalink)
Yea Buddy! I like them boots. Ive had my eye on them. Im a Redwing man and I also have some Danner boots but that Chippewa boot rocks and Ill bet its a pretty good quality. It looks like it has a double layer where the shifter hits.
Old 11-29-2006, 07:17 PM   #10 (permalink)
Hey Joe is on a distinguished road
I wish I could find some gloves warm enough that I needed to worry about warmer boots but right now my fingers give out long before my feet would.
Hey Joe is offline   Reply With Quote
Old 11-30-2006, 01:05 AM   #11 (permalink)
SSC
SSC
Thanks for all the info. I went and tried on some red wings. I have wide feet and their wide is not wide enough. I was told at the local stealer that the fxrg boots don't come in a wide size. I have some of the chippewa's coming to the local bootbarn. They ordered some for me to try. If they are wide enough we may have a winner.
Otherwise, I will stay with the heavy wool socks and the non insulated boots I wear. They seemed to be warm enough with the heavy socks on rides to No. Cal and Reno down to the 40's. They have also been crash tested .
Cabela's has a nice leather inexpensive hunting boot, that can be ordered with insulation. Just another option.
Once again, Thanks--SSC
