Leslie Kay'sRRcycles.comJardineProducts.comMBO EnterprisesJekillandHyde.eu
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Forum Sponsors Section > Revolution Performance
CycleGear.com
Old 01-10-2007, 04:22 PM   #1 (permalink)
Revperf
revperf is on a distinguished road
Mild Revperf 135" Jim's Big Bore Motor
This engine was built by Revperf's own Dusty Werner for a customer with an Ultra Classic.
Specs: Originally a OOB Jim's Injected 120
RP Ported Heads - OEM Valve Train Retained
RP 135" Big Bore Kit - 10.5:1CR
RP Prepared Flywheel Assembly
S&S 640G Cams
HP Inc. 62mm Throttle Body
V-Rod Injectors
PCIII-R
D&D Boarzilla
This motor has soooooo much more in it given the amount of CR that was used with the 640G cams. The customer was after an engine that would run on anybody's gas anywhere. The torque numbers reflect the lower dynamic cylinder pressure but the HP number is still waaayy impressive. To say that this is one bad Ultra is a real understatement. Pulls a trailer good too.
Brian
revperf is offline   Reply With Quote
Old 01-10-2007, 05:28 PM   #2 (permalink)
Snap-on man
BIG MAN's Avatar
BIG MAN is on a distinguished road
dam thats sweet, I would be real happy with that ultra.
98 in GMR, 10.8.1, R&R CAST HEADS, 51MM HP INC THROTTLE BODY, 615/585 GEAR DRIVE CAMS, RINEHARTS, 3.37 GEAR, RIVERA PRO CLUTCH.WOODS AIR CLEANER. 125.4HP 115.8TQ
BIG MAN is offline   Reply With Quote
Old 01-10-2007, 06:27 PM   #3 (permalink)
Me likey!!
'04 Brilliant Silver FLHRSI
Old 01-10-2007, 09:14 PM   #4 (permalink)
Cdouthitt is on a distinguished road
Wow...but I hardly qualify a 135" 'er being mild.
Clint
2005 FXDi
Khrome Werks HP+
Big Sucker
43 Timer Cover
Cdouthitt is offline   Reply With Quote
Old 01-10-2007, 09:36 PM   #5 (permalink)
Mattman22033 is on a distinguished road
That is awesome. I wonder what kind of gas mileage you get with an engine like that...lol.
2006 Road Glide 95"
HD Stage II Big Bore
SE 203 cam
SE air kit w/K&N
V&H true dual headers
V&H Monster Ovals exhaust
PCIII USB w/custom map
SE 6 speed
HD premium oil cooler
Chopped tour-pak
Ultra style lowers
Clearview windsheild
Chubby pullback bars internally wired
Braided lines
82.49hp
91.29ft-lbs
Bi-Xenon HID lights
Hogtunes upgrade
Kuryakyn driving lights
Mattman22033 is offline   Reply With Quote
Old 01-10-2007, 09:52 PM   #6 (permalink)
DEVILDOG's Avatar
DEVILDOG is on a distinguished road
Gulp...
DEVILDOG is offline   Reply With Quote
Old 01-11-2007, 08:37 AM   #7 (permalink)
Doofhead
Brian, too bad the owner didn't let Dusty step on it a little harder.
Totenkopf is offline   Reply With Quote
Old 01-11-2007, 09:52 AM   #8 (permalink)
Revperf
Yeah, believe me he kicked and screamed and to be honest I was concerned with potential end result myself. When I consult on one of these motors I have a tremendous obligation to deliver the goods because of the amount of money, time, and emotional attachment there is with the bikes. The only real issue I had was cylinder pressure because of my experience with these cams. Just ask d'Wrench. The physical size came into play though and cushioned the blow. No pun intended.
As for it being a mild build or not. It really and truly is. It's just big. Keep it in perspective that this motor would be like building a 114 out of a TC88. Other than the cams and the T-Body essentially all the components from the "factory" were retained.
Thanks to all for the responses.
Brian
www.revperf.com
Old 01-11-2007, 10:50 AM   #9 (permalink)
turbotc is on a distinguished road
Brian
www.revperf.com
If 162 HP for 135 Cubic Inches is mild, please tell me what your build performance describtion scale is for each of the below! I want to know how bad my engine's performance is....LOL
I'd love to just get a 1.1 HP per CI out of my 124. That's SAE 1.1. But then again, I only have about 2/3 the cam that engine is using.
1 HP per CI = 135
1.1 HP per CI = 148.5
1.2 HP per CI = 162
1.3 HP per CI = 178
turbotc is offline   Reply With Quote
Old 01-11-2007, 11:10 AM   #10 (permalink)
V-Rod Kit is on a distinguished road
1 HP per CI = 135
1.2 HP per CI = 162
1.3 HP per CI = 178
personally, i would consider 1.2 HP per cubic inch pretty mild.
my 347 camaro SS daily driver makes 423 at the wheels (over 520HP at the crank with 20% drivetrain loss), while not mild it is very streetable and makes 1.5 HP per CI and it's just a regular old pushrod V8...but what do i know...
Kit Sloan
'02 SOM SS M6
- 11.64 @ 119 mph NA on ET Streets - 12.44 @ 88 mph on drag radials :P
'05 Chopper Blue VRSCA V-rod - 12.0 @ 115 mph - Lot's of Chrome
V-Rod Kit is offline   Reply With Quote
Old 01-11-2007, 12:02 PM   #11 (permalink)
Doofhead
It's easier to make 1.5hp/ci in a V8 than it is in a air cooled V2. trust me!
In the race gas drag bike engines we have, we get close to 2hp/ci but that is an all out assault motor set on "kill" but still is meant to be somewhat reliable.
Old 01-11-2007, 12:06 PM   #12 (permalink)
Kit Sloan
'02 SOM SS M6
Your SS at the rear wheel just like that 135" HD is 1.2 HP per CI at the rear wheel too.
Most consider 15-17% drive train lost on cars. At 20% loss that 135 would be around 194.5 HP at crank for a 1.45 HP per CI engine. Not to mild to me at that either.
I for one, an I think most of of us consider what a dyno says engine power is applied to the drum/rollers.
Old 01-11-2007, 12:12 PM   #13 (permalink)
Doofhead
Brian
I know you were playing a balancing act with getting just enough compression to get the cam to "turn on" versus satisfying the pump gas requirement and still getting enough air through the motor to let it breathe.
You done good! I love big dumb motors like that for big heavy bikes.
Out of curiousity, have you ridden the bike? Was wondering how it spools up with it being 4-3/8" by 4-1/2".
Old 01-11-2007, 12:14 PM   #14 (permalink)
mooooving out!
route66paul's Avatar
RP ported heads? Is this a stock head that has been ported, or has it been revalved? Are the revperf heads? There is a lot of difference.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
route66paul is online now   Reply With Quote
Old 01-11-2007, 12:14 PM   #15 (permalink)
i would consider 20% loss on my particular car (read: extremely heavy duty drivetrain) pretty conservative, but 15%-17% is the standard most would use on factory cars.
yup, you're right...didn't consider the bike was at the rear wheel, DOH!
doesn't sound like nearly as mild of an engine now that i take that into consideration. 1.2 HP per CI at the crank i would still consider very mild, but since that's not what we're talking about here i retract my statement on this engine.
