HR 107 2012, the Impeachment of Obama : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Forum Non-Motorcycle Related Forums > Religion & Politics
Old 11-09-2012, 04:41 PM   #1 (permalink)
Hater of the dyno!!!!!!
Jeffytune's Avatar
Well this happened even faster then i thought it would. I knew the Republicans had it up there sleeve to Impeach Obama if he won.
Let the president be duly warned.
Rep. Walter B. Jones Jr., R-N.C., has introduced a resolution declaring that should the president use offensive military force without authorization of an act of Congress, “it is the sense of Congress” that such an act would be “an impeachable high crime and misdemeanor.”
Specifically, Article I, Section 8, of the Constitution reserves for Congress alone the power to declare war, a restriction that has been sorely tested in recent years, including Obama’s authorization of military force in Libya...
Read more: http://nation.foxnews.com/president-...#ixzz2BlfdOfqI
Regardless of why they pull him in front of a congress, he will finally be forced to answer the questions of his birth and college and passport.
And we all thought the election would be the end of this for a while, hang on all, it's going to get a bit bumpy.....
I'm Just Sayin'...
2007 FLHT 103 CID SE-255
IDS drive W/30 tooth Andrews
K&N Air filter system
Torque(A bunch) HP(enough)
Professional Rockat Surgen
Disclaimer.
Old 11-09-2012, 04:45 PM   #2 (permalink)
RGRider's Avatar
RGRider is on a distinguished road
Waste of time. The left will just call it sour grapes and the media will ignore it.
RGRider is online now   Reply With Quote
Old 11-09-2012, 04:47 PM   #3 (permalink)
thrasher's Avatar
thrasher is on a distinguished road
Lightbulb
They are really grasping for straws now, and still in denial.
... and just what would you expect out of a rightwingnut majority HR? All kinds of goofy idiotic radical resolutions will come forth. It doesn't mean that they will ever go anywhere. Pretty un-newsworthy.
Never try to teach an pig to sing; it wastes your time and it annoys the pig.
If at first, you fail miserably, try the same thing again expecting different results.
thrasher is offline   Reply With Quote
Old 11-09-2012, 05:03 PM   #4 (permalink)
HDSickness is on a distinguished road
Typical libtard response..........Ignore and shrug off anything negative about the savior Osama....I mean Obama.
Keep your head buried deep in the sand.
HDSickness is offline   Reply With Quote
Old 11-09-2012, 05:12 PM   #5 (permalink)
James's Avatar
James will become famous soon enough
That's just great. If Obama gets impeached we get Biden as President. How's that for change?
James is offline   Reply With Quote
Old 11-09-2012, 05:34 PM   #6 (permalink)
thrasher's Avatar
Typical rightwingnut response: resort to personal attacks.
Old 11-09-2012, 05:38 PM   #7 (permalink)
Jeffytune's Avatar
Not so fast James, if they get to find out he was not a eligible candidate, they can could decide to vote in Romney in December....
I'm Just Sayin'...
Disclaimer.
Old 11-09-2012, 05:44 PM   #8 (permalink)
thrasher's Avatar
Thumbs up
I'm pleased that the rightwingnut conspiracy theories live on. It is most excellent entertainment.
Old 11-09-2012, 06:11 PM   #9 (permalink)
blubyubusa is on a distinguished road
date on article
Unless I misread that date, the article is dated March 11. Does not look like anything will ever come of this or anything against Obama. And if he is called in front of congress, he will answer as well as Clinton about sex in the oval office with Monica.
blubyubusa is offline   Reply With Quote
Old 11-09-2012, 06:30 PM   #10 (permalink)
Casey0211's Avatar
Casey0211 is on a distinguished road
Jeffrey, I would suggest you educate yourself about what impeachment actually is rather than what you think it might be before you assume the president will be "forced" to do anything at all. This is nothing but a Right Wing dog-and-pony show that will end just like the Clinton impeachment (you know, the guy who helped clean Romney's clock on Tuesday). What it might do is infuriate enough voters to give the GOP another kick in the ass in the mid-terms.
So be my guest.
Casey0211 is offline   Reply With Quote
Old 11-09-2012, 06:39 PM   #11 (permalink)
Jeffytune's Avatar
As I said, It's going to be a bumpy ride all.
I'm Just Sayin'...
Disclaimer.
Old 11-09-2012, 06:46 PM   #12 (permalink)
Thanks! I needed that.
Scabbydoo's Avatar
Scabbydoo is on a distinguished road
Your sh!ttn' me right. The impending "Fiscal Cliff", an economy still in need of a lot of work, the entire middle east in a state of flux and the discussion is still about his birth certificate and now potential impeachment proceedings.
And yet people wonder why things are so fukk'd up.
"Age is a case of mind over matter. If you don't mind, it don't matter." Satchel Paige
95" Bore by Zippers - Wiseco 9.5 Pistons - T-Man StageII Heads - Andrews 37G Cams - Stock Crossover Dual Headers
Samson Fishtail SlipOn's - TTS Mastertune - Build and Dyno by JD's Cycle Works
HP=98.03 - TQ=102.14 Uncorrected
HP=93.36 - TQ=97.27 SAE Corrected
Cost of build, about right. Value of grins, PRICELESS!
Scabbydoo is offline   Reply With Quote
Old 11-09-2012, 07:53 PM   #13 (permalink)
Thermodyne's Avatar
Thermodyne is on a distinguished road
It is kind of old news, as is the birth record and such.
Personally, I think that every member of congress should have one thing on their plate. Passing a balanced budget. Time really is running out. The fed has basically been printing money for 2 years now and with interest rates at near 0, this whole smoke and mirrors financial system is going to blow up. At some point the administration is going to have to face up to inflation. They can only use the housing crash to write it down for so long. And when the fed has to raise interest rates to curb inflation, the cost of service the debt starts to climb. In less than three years, it explodes.
Every where you look, consumer prices are rising. Food, energy, healthcare, transportation, local taxes, you name it and it's going up. So some are saying that we already have an actual inflation rate over 5%. What happens if it gets to 10 or 15%? Any of you old enough to remember the late 60's and early 70's? It wasn't pretty then and it will be worse now.
Seriously, we can't afford two more years of the inter party conflict. We need to put it aside for a while. Hey I'm a republican, and where I live we lost bad. What with the damn Tea Party and Christian radicals, I'm surprised it wasn't worse. It's time to face facts. The government is us, and us is broke! And all the impeachments in the world won't fix the problem.
"All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
Thermodyne is offline   Reply With Quote
Old 11-09-2012, 08:32 PM   #14 (permalink)
not sober all the time
Uncle Salty will become famous soon enough
I say let it go. Biden would screw it up worse. Obama said he could fix it then spent 3 1/2 years blaming Bush. Give him four more years. I've got a bet on him.
Uncle Salty is offline   Reply With Quote
Old 11-09-2012, 08:33 PM   #15 (permalink)
Scabbydoo's Avatar
Originally Posted by Thermodyne View Post
....Seriously, we can't afford two more years of the inter party conflict. We need to put it aside for a while. Hey I'm a republican, and where I live we lost bad. What with the damn Tea Party and Christian radicals, I'm surprised it wasn't worse. It's time to face facts. The government is us, and us is broke! And all the impeachments in the world won't fix the problem.
Finally, someone speaking some sense. Now, if the "esteemed colleagues across the aisle" can put aside their pet issues and ideology and focus on real solutions to the real problems at hand, perhaps something might actually be accomplished.
But currently I am not prepared to hold my breath.
